Afr Jumping and mapping (alfa 3.0v6)
Postby gtv-racer » Sat Aug 11, 2012 12:18 pm
Hello,
Some problems here.
My engine setup:
Alfa 3.0V6
Dis coil (ford)
New injectors (340cc/min)
At first why is my calculated Ve mapping so off. Had to adjust it a lot and it stil needs a lot of work.
Did calculate it with the generator in megatune. Filled in my engine spec's. But then it was a lot to rich.
And second: I have a lot of short peaks towards the lean side. Also the engine cough a lot. I don't see why.
Something what crossed my mind when i used the timinglight that it didn't work on al the plugs.
Coils are fired in sets. Al the sets fired fired with the trigger light but only the upper part. When i puled out the plug that didn't fire on the timinglight, it fired just fine outside the engine :?
anyone any thoughts?
2012-08-11_21.04.15.msq
ms2 extra file
(83.26 KiB) Downloaded 12 times
2012-08-11_16.17.28.msl
datalog
(329.23 KiB) Downloaded 14 times
gtv-racer
Re: Afr Jumping and mapping (alfa 3.0v6)
Postby gtv-racer » Sat Aug 11, 2012 1:27 pm
Maybe something with the feul delivery. Because it's going lean?
gtv-racer
Postby gtv-racer » Sun Aug 12, 2012 3:32 am
I als0 think when i look at the log that te labda sensor is broken. Could it be it got clogged. Had a lot of starting issues at the beginning. Much bleu smoke..
Can you clean it if so and what's the best way to clean it?
gtv-racer
Postby kjones6039 » Sun Aug 12, 2012 5:02 am
Blue smoke is more often caused by engine issues rather than fueling! (rings, valve guides etc.)
383 CID SBC w/ Holley Pro-Jection 900 CFM TBI, 4-85 lb lo-z injectors & Walbro 255 pump
MS2 v3 w/Firmware? Depends on the phase of the moon. Currently-ms2extra_pre3.3alpha5_gslender_v2.8a
Wasted spark, 36-1 wheel, Ford coils, 4 coil driver board from JBPerformance
SLC OEM WB from 14point7
kjones6039
Postby gtv-racer » Sun Aug 12, 2012 12:06 pm
Bleu smoke is gone now. And the engine didn't smoke bleu before i built the megasquirt on.
Think there was some oil in the engine (partly rebuilt it).
Tanks for the thoughts on it!
Some other ideas someone?
gtv-racer
Postby haklis » Tue Aug 14, 2012 10:53 am
Maybe you should get your fuel injectors checked / cleaned?
I have had the same issue with my car. Some of the "noise" on the AFR disappeared when I ditched the direct coil drive and installed EDIS. Still there are some lean spikes and I am going to clean my injectors in ultrasonic cleaner. During a sylinder head rebuild I saw that one exhaust valve stem had a white color. This might be the one cylinder that is the cause. Maybe you have the same problem?
Megasquirt project car: Escort mk2 mexica replica with 2litre pinto on GSXR ITB's. EDIS. MS2extra
haklis
Postby gtv-racer » Thu Aug 16, 2012 1:36 pm
that is a good one. Injectors are changed for bigger ones. They are second han so they might be the problem. Going to check them.
Thanks for your anwer!
gtv-racer
Postby gtv-racer » Sun Aug 26, 2012 8:13 am
lambda problem solved. Very strange. Setting where set to default. That's the second time and i'm sure i didn't touch them :|
Anyone got a simple setup for injector testing?
gtv-racer
Postby LAV1000 » Sun Aug 26, 2012 10:28 am
Injector testing,
I used output test,clean glass jar's and a kitchen scale.
So you can measure the weight each injector produces and calculate back to cc if you want.
Go for nearly full jar's so faultmeasure is lesser depending on accurate of the kitchen scale.
LAV1000
Postby gtv-racer » Mon Aug 27, 2012 11:12 am
Looks like a good idea! Thanks.
one problem. It shoul be under the tools tab but i can't find it. Is it a plug in?
gtv-racer
Postby LAV1000 » Mon Aug 27, 2012 1:30 pm
No its not a plug in.
Open your projekt and tune and look under the advanced tab.
LAV1000
Postby gtv-racer » Sat Sep 15, 2012 1:50 am
Thanks, found it. gonna play with it today! Hope this sorts out the cuoghing of the engine!
gtv-racer
Users browsing this forum: Bing [Bot] and 2 guests
