AEM uego wideband
AEM uego wideband
With MS2, which wideband shoud I chose when using the AEM uego wideband? I've tried the aem linear and the aem non linear but both display 16 AFR with the engine off. With my LC1, it shows 21 with the engine off . Even the generic wideband displays 16 with the engine off. The AEM gauge displays ---.
Re: AEM uego wideband
Which AEM part number is it?
It's the standard gauge type UEGO controller, 30-4100.
I guess I will use a generic linear wideband with 10 AFR @ 0V and 19.98 AFR @ 4.99V. If the wideband is good, this should work.
take a look at this :
http://www.msefi.com/viewtopic.php?f=38&t=35569
Check the last post, mainly.
Sam
Sam
Link doesn't work, can you repost it?
yes what pit_celica said works pretty good works pretty good.. u can try these settings in Tunerstudio and its .1+/-
Ok thanks, will try these settings.
