Speed pulser and MSII extra
Postby TBI_Master » Tue May 15, 2012 6:57 am
My car has a speed pulser already installed. Can I feed those pulses to any free input in my MSII/Extra and get either the pulses/sec, or the time between one pulse and the next one?
TBI_Master
Re: Speed pulser and MSII extra
Postby TBI_Master » Wed May 16, 2012 2:53 pm
What happen is that I am sending the whole data stream to one microprocessor, and that micro is tied to a LCD where I see all the important data of my engine.
I was just thinking if there was a spare counter/capture module in the MS controller. If not, then I will wire the speed sensor to the micro and it will compute and report the speed straight to the LCD. The problem would be when i connect the laptop instead of the LCD, I would not have the car speed.
TBI_Master
Postby jsmcortina » Wed May 16, 2012 2:58 pm
There isn't an existing feature to do this, but the source is available if you wish to add it yourself.
I can supply, repair or upgrade Megasquirts in UK.
Postby fixmann » Thu May 17, 2012 4:32 am
Hi
One solution is to use a fequency to voltconverter.
This way you can use ADC6 or ADC7 to capture speed.
Øyvind
fixmann
Postby 16vboost » Thu May 17, 2012 5:15 am
How does MS3 accept VSS pulses? Does it have extra hardware on the daughter card? I thought it just had to be tied to a spare digital input?
-Alex
16vboost
Postby TBI_Master » Wed May 23, 2012 8:47 pm
fixmann wrote:Hi
Øyvind
I like this idea. I do have a PCB that does exactly that...Thanks!
TBI_Master
Postby Matt Cramer » Thu May 24, 2012 5:12 am
16vboost wrote:How does MS3 accept VSS pulses? Does it have extra hardware on the daughter card? I thought it just had to be tied to a spare digital input?
-Alex
You can either use a voltage based signal to an analog input or a square wave signal to a digital input.
Users browsing this forum: Bing [Bot], DaveEFI and 4 guests
