I now have it running full sequential stand alone on a 408 Mopar Magnum R3 block using the factory hall sensors and trigger wheels. It started on the first try and within a couple of hours of tuning I took it for a drive. Here are some of the engine specs, plan is to turbocharge within the next year or so. Still have plenty of tuning to do then off to the Dyno for Timing map and final tuning.
4" stroke
4.03" bore
9.5:1 CR
Forged internals
Indy 210 CNC Heads w/ T&D rockers
Wilson 105mm TB
GM 4 wire IAC stepper
.544 lift 236@0.050" roller cam
80# injectors
HiPoTek -8 Fuel rails
46RH trans with 3k PI Viper Converter
Still need to figure out how to control the OD with the MS3 if anyone has any ideas or knows if this can be done or not.
