Hi just pondering the idea of trying this ITB tuning out as I have a 2.3 liter with dual48 Jenveys and have battled crisp throttle response for ever. ( same motor has killer response with 48 IDA'S )
I have the latest TS and in the ITB load settings window I do not have the options at the bottom of the screen for changing the Percent baro switch point and the Idle tps threshold
I am reading the instructions with sample screen shots here http://www.77e21.info/mstuning_itbmode.htm
Does TS now just default to 90% for the switch point or something ?
Thamks in advance.
Darren
ITB load settings window ( question.)
Re: ITB load settings window ( question.)
What firmware rev are you on?
Hi I'm on the latest firmware 3.3.1a.
Ms2 does not support the settings you refer to.
