Background:
- MSPNP-DIY with microsquirt module
- custom additions board that communicates with the MS over the CAN bus
- originally just using the gpioadc and gpioports to communicate to/from to the MS2, works fine
I am in the process of setting up the CAN device in TS so I can update configuration without needing to connect a programmer. I have the start of an ini file that I've attached. However, TS says that it can't communicate. The appropriate lines in the comm debug are:
Code: Select all
4/20/12 12:27:11 AM :Info: Going Online with MS2/Extra release 3.2.1 20111221 14:40GMT (c)KC/JSM/JB u
4/20/12 12:27:11 AM :Info: Comms Watchdog is inactive
4/20/12 12:27:11 AM :Info: Started Comms Watchdog
Time: 0:01.232: SENT, 7 bytes
x72 x07 x0F x00 x00 x00 x14
4/20/12 12:27:11 AM :Debug: High Speed Paint: true
4/20/12 12:27:11 AM :Debug: !!! Opened Dash 1352
Time: 0:01.632: Received, 20 bytes
x42 x57 x20 x4D x53 x32 x20 x41 x64 x64 x6F x6E x73 x20 x76 x31
x2E x30 x30 x00
4/20/12 12:27:12 AM :Warning: Unsupported Controller Firmware.
Any ideas? I don't see any other requests to my device except for the 3 requests to get the signature.
Brett
