by oldskool » Thu May 17, 2012 2:16 pm
Matt, Thanks for the reply. Can you view tune & see my settings? During assembly of MS3, testing with Stim, R56 pot had to be adjusted different than VR input. I had a post Feb 27th about this. At first Stim would see tach signal if I turned R56 in 6 turns, later after backing off R56 adjustment all way for VR in car, wouldn't get siganl from HEI7. Turned R56 back in 6 turns for Stim to test, wouldn't get signal, tried all way from full couterclockwise to 6 turns, couldn't get tach input from stim. Finally put in car, left cover off MS3 being careful to avoid grounding board & shorts. I turned R56 all way counter clockwise, then cranked engine over while turning slowly clockwise till my NOID lite flashed, same time LED blinked. (about 2.5 - 3 turns). I left adjustment alone. Could the R56 be the problem? Thanks,
David
77 Pontiac 400 stock 190HP test engine,
HEI7 controlled w/MS3X,
bank 2 bank port w/38's,
LS1 75mm TB,
GM 4 wire stepper IAC,
5,000 Altitude,
91 octane
200 4R
- Attachments
2012-05-16_14.59.52.msq
- Lastest from laptop
- (129.58 KiB) Downloaded 7 times
