TS 2.0.1 funnies
TS 2.0.1 funnies
Postby Philip Lochner » Thu Jun 14, 2012 7:47 am
Hi Phil
Upgraded to TS 2.0.1 and find a few oddities:
1) Upon upgrading TS, I got the message as per attached pic;
2) Now every time I start TS, it seems to think that another instance of TS is running - when it does not seem to be the case
3) The help message on the Vbatt calibration page refers to kpa when it should be Volt. (Still not quite sure how this is meant to be done - I've always used an adjustable resistor to fix Vbatt calibration)
TS 2.0.1 error message.JPG (12.48 KiB) Viewed 211 times
Kind regards
Philip
My Project Cars: http://www.jaguardiy.net
Philip Lochner
Re: TS 2.0.1 funnies
Postby LT401Vette » Thu Jun 14, 2012 7:59 am
When did you update? that message should be fixed now on the update.
If you run the installer it will repair that.
The check for another running instance is a 2 way conversation, the starting app asks if there are any TS's running out there, if it is saying there is, someone must have answered.
Check your task manager, it will likely show up as javaw.exe in processes. I'm betting you do have a hung instance of TunerStudio running. It may have hung do to the above message., Actually the above message may be getting caused by the hung instance. It can not update the files if they are locked by another running instance.
What firmware?
LT401Vette
Postby Philip Lochner » Thu Jun 14, 2012 8:22 am
Hi Phil
1) I updated less than 30 min before posting.
2) I found TWO instances of javaw, killed them both and now that issue is sorted, thanks!
3) The kpa issue was on fw 3.2.1
Kind regards
Philip
Philip Lochner
Postby LT401Vette » Thu Jun 14, 2012 8:36 am
Ok so the other instances should explain why it didn't update, but, auto update should have prevented the restart until the other instances where exited, or if it gave up waiting should have prompted you.
In the MS2 Extra 3.2.3 ini the kPa looks to be fixed.
LT401Vette
Return to Tuner Studio
