I have been kicking around trying out MAF mode on my 4AGE 20V instead of ITB mode seeing I have had a MAF sensor installed since using MS1, so I have been logging MAF and MAFMAP to see what ranges to set various tables to. When I got to the "MAF correction" table, I noticed that the range of MAF flow would be twice what I needed so I set the numbers to something closer for a starting point BUT when doing that now have all the points on one side of the displayed graft. SO.....................
What I am asking, would it be possible to have the table re-scale itself based on the numbers in the columns? Just seems it would make it a little easier to "see" the curve if it could use the whole window. see pic
just asking, wd
