Rather than changing ignition maps, which may already be fully in use, would it be easy to to implement a spark advance adjustment to the whole map using one of the spare inputs?
For example 0-5v input would correspond to a 0-5 degrees of advance added to the ignition map. This would neatly cater for different fuel types. I would envisage this being used simply as a pot or rotary switch under the dash somewhere and switched up or down depending on the fuel grade selected.
kind regards
Marek
