savagerocco wrote:So, are we gonna get anymore info about this? What kind of sensors will it support? I can't wait for this upgrade!
masterx81 wrote:The readout is via an analog pin or via spi communication? On the pdf of the tpic seem that the adc output can be read via i2c (so a pin can be freed)
masterx81 wrote:That's so nice & clean! Thanks!
The pin used for CS can bee freed up on the cpu if there is only one device in the spi 'chain', leaving pulled up the cs pin on the knock board?
Reverant wrote:The TPIC8101 only works with the resonant-type knock sensors. It doesn't work with flat response sensors.
masterx81 wrote:Reverant wrote:The TPIC8101 only works with the resonant-type knock sensors. It doesn't work with flat response sensors.
The knock sensor is only a piezo microphone, i not see why it must not work with flat response sensors. The 3rd order bandpass filter is here to filter unwanted frequencies...
