Frequency = 41 (6.94 kHz)
Gain = 63 (0.111)
Integrator = 24 (320us)
Somebody should correct me if i'm wrong (please)? (and i guess i'm wrong for sure like most of the time.........
jsmcortina wrote:I don't think there are enough pins on the MS3 to be able to do that. Certainly the current design doesn't permit that.
gross polluter wrote:Not having much luck with mine. Seems like there needs to me more attenuation before the signal gets to the ic,
gross polluter wrote:Not having much luck with mine. Seems like there needs to me more attenuation before the signal gets to the ic, at least with the factory 2JZ knock sensors. With the gain set to 1 the knock gauge always reads 101% with the gain at minimum the knock gauge bounces between 50% and 70% at idle and reads 101% off idle. Haven't had much time this week to tinker beyond installing the module and running it as-is.
HeinrichG wrote:jsmcortina wrote:I don't think there are enough pins on the MS3 to be able to do that. Certainly the current design doesn't permit that.
That's really pity![]()
Regards,
Heinrich
elaw wrote:First, in general the board seems to be working well on my 5-cylinder Audi engine with two sensors.
In the "knock sensor settings" window, can you confirm or deny my guess as to how "retard check time" and the coarse and fine steps work? My guess is the 1st time knock is detected, it retards by the coarse step. If knock is detected again within the "check time" it retards again by the coarse step, otherwise by the fine step. Am I right?![]()
Also a minor issue: although I've got the advance check time and step size both set to 0.5, it seems to advance in 1-degree increments at 1-second intervals
And lastly a request: any chance of being able to log knock value per-cylinder?
elaw wrote:Do you know if your engine has a resonant knock sensor? From what I've read, the resonant sensors have a much higher output (like 10x higher) than the non-resonant ones.
Regards,
Heinrich
Any advice on setting integrator time constant? Can't really figure that one out.
tpsretard2 wrote:Could this be some area that can be worked on then, the indicator i would not of though you would want staying on at all. maybe a delayed turn off, but not a stay on all the time.
also the knock counts, i am amusing this how many time is crosses the set threshold right ??
