OliverH wrote:@Keith
This is your current setup?
OliverH wrote:Hi Keith.
Sorry for mixing up this two setups.
Do you know which kind of signal is on the knock detect pin of the DI? Is this a still interpreted signal?
By the way. The 900 classic 16s wasn't allowed to be called Aero at that time in most countries of Europe, as Opel had a very unknown Kadett convertible called aero years ago and hold the name.
Oliver
During engine operations the Ignition cassette continuously monitors the ion currents in the cylinders
and sends a signal to the Trionic ECU on pin 44, in the event of knocking. The logic for this function
rests solely in the ignition cassette and is adaptive to be able to handle disturbing fuel additives. The
Trionic ECU is well aware of which cylinder that has ignited and could hence cope with the information
fed through one pin. The signal to pin 44 and ion current in the combustion chamber is related to
each other. When this signal reaches a certain level the ECU interprets this as a knocking event and
firstly lowers the ignition advance by 1.5° on this cylinder. If the knocking is repeated the ignition
advance is lowered further by 1.5 °, up to 12°. In case of the same lowering of the ignition timing
advance in all cylinders the ECU adds a small amount of fuel to all cylinders. If knocking occurs when
the MAP is over 140 kPa the knocking is regulated by switching both fuel injection matrix and ignition
advance matrix. If this is not sufficient the charging pressure is lowered.
karlo wrote:James, what circuit did you use in order to read the ion current? I've been wanting to try this myself.
Initially, I think it would be more than sufficient to process the ion current signal off line (eg. in TunerStudio or in a separate application). Doing it real time would be nice, of course, but substantially harder and most of the benefit can be had with an offline solution.
bubba2533 wrote:I'm not sure that would even be possible at high rpm.
jsmcortina wrote:Apparently at higher rpms you also find that you cannot ion-sense with inductive ignition because the discharge phase overlaps the PPP. That's why all(?) ion sense systems use CD ignition.
OliverH wrote:Would this Italian link help to rebuild the electronic part of the Trionic?
http://www.saabwayclub.it/forum/viewtop ... 14&t=14618
