I've been doing a lot of research on EGT and I had some thoughts. First, though, I thought I'd provide my setup so you have an idea what I'm working with. I have an aircooled VW bus and it has 4 CHTs and 4 EGTs that are being brought into the MS3 via Jean's IOX. For the most part everything seems to be working great. I'm using the Generic Sensor inputs for the CHTs (CAN ADC09-12) and now I'm bringing in the EGTs through the EGT/Thermocouple settings (CAN ADC13-16).
I was looking at the EGT settings page and I noticed that there are various actions for excessive EGT temps and after some further readings, I'm thinking that those settings might not really be valid. According to this page (http://www.ls1tech.com/forums/advanced- ... 101-a.html), detonation will cause the EGTs to drop, not go up, which honestly was a surprise to me. I'm wondering if those EGT temp settings are really even useful. Again, I'm no expert in EGT, but that article seemed pretty enlightening and I wanted to hear some thoughts on this.
That said, I think the warning system on the EGT page is very applicable to CHT. When the engine gets hot and gets closer to pre-ignition/detonation conditions, the CHT goes up, so it would be great if there were some means to use that page for CHT as well, maybe with its own warning/handling system? Or I guess I could use that page for CHT instead of EGT, but the labels would be confusing.
That brings me to my last issue, would it be possible to make some adjustments so that the thermocouple settings were more CHT friendly? It would be great if the CHT values would get datalogged as CHT01 instead of Sensor 01. I know aircooled engines are the minority, but you have all done a great job in accommodating the aircooled folks with other temp settings throughout and I wanted to see if we could bring in the measurements somewhere like the EGT page along with warning so that engine conditions can be adjusted should a high-temp condition be reached.
Thanks,
Mike
