MS3 pre-1.1 beta 24 released
Postby muythaibxr » Sun Jun 03, 2012 6:35 pm
Changes since beta 23:
- Fix ini to un-grey MS3X inj trim when non-sequential.
- Add the ability to tie Idle VE or Idle Advance activation to PID idle activation
- Make FC rotary trailing back the way it was. Tester had his CAS stabbed wrong.
The firmware can be found here:
http://www.msextra.com/doc/ms3/files/be ... beta24.zip
muythaibxr
Re: MS3 pre-1.1 beta 24 released
Postby wrenchdad » Mon Jun 04, 2012 5:52 pm
Ken,
Did you or James see what I wrote about the AC controls in this R22 link?
http://www.msextra.com/forums/viewtopic.php?f=125&t=45289&start=20
Just not sure if its a bug or that's just the way its suppose to work? Just telling so you guys would know about it before ya'll do the release version.
thanks for all that you guys do!!
later wd
wrenchdad
Postby muythaibxr » Mon Jun 04, 2012 8:39 pm
I have not looked at that issue yet.
muythaibxr
Postby wrenchdad » Mon Jun 04, 2012 9:09 pm
Ken,
Ok, just wanted to make ya'll knew about it.
thanks wd
wrenchdad
Postby jsmcortina » Tue Jun 05, 2012 10:20 am
Sending a test firmware.
I can supply, repair or upgrade Megasquirts in UK.
Postby wrenchdad » Tue Jun 05, 2012 9:42 pm
jsmcortina wrote:Sending a test firmware.
James,
Loaded the test firmware and can happly say that the turn-on issue for AC is gone !! :yeah!: I can't say for the fan side of things but tried it several times to make sure it would come on between settings, that the delay was still working and the cutoff still worked also. All is well.
BIG Thanks !!!
wd
wrenchdad
Postby 13bdarren » Thu Jun 07, 2012 6:24 pm
i am having error codes with loading in tunerstudios
Says \root problem invalid row in ini file.Not sure how to handle this row
maincontroller.ini line 230 burncommand
maincontroller .ini line 231 pagereadcommand
maincontroller.ini line 232 pagevaluewrite
I have tried it to 2 computers with no luck. They are running window 7 so that might be the problem. Any help would be great.
13bdarren
Postby 93white3400z » Thu Jun 07, 2012 7:03 pm
Make sure you're running the beta TunerStudio.
MSDroid (Android App) for MegaSquirt available for free!
Like MSDroid on Facebook
1993 Chevrolet Cavalier Z24
3400 Turbocharged Intercooled
MS3 v3.57+MS3X
93white3400z
Postby 13bdarren » Fri Jun 08, 2012 1:21 pm
cool thanks I will try that.
13bdarren
3-wire PWM idle problem
Postby shauer » Sat Jun 09, 2012 2:58 pm
Just updated from beta 20 to beta 24. I noticed that my closed loop idle was not working as expected. I'm running a 3-wire pwm idle control valve at 99Hz. Normal operating range is approximately 25% - 50%.
The "hum" coming from the idle valve does not sound correct, it is much higher in pitch than it should be. It sounds like it is running at well over 1KHz. The valve does not open and close as expected, it takes up to 75% to get it to start opening and then it overshoots.
I tried changing PWM frequency all the way down to 12Hz with no noticeable change in my idle valve operation. The valve was just working correctly yesterday when I parked the car and has never malfunctioned in the past 3 years.
Is it possible that low frequency 3-wire PWM idle was effected by any recent changes?
MSQ is attached.
2012-06-09_17.27.25.msq
(160.53 KiB) Downloaded 12 times
Steve Hauer
http://www.77e21.info
1977 BMW 320i with ITBs, MAF tuning, COP, IAC, Sequential fuel and spark, MS3 knock sensing
MS3 / MS3X / V3 mainboard, MS3 pre-V1.3 alpha 4
Tuner Studio 2.2.06
shauer
Postby muythaibxr » Sat Jun 09, 2012 5:06 pm
I do not know of any changes that should have affected the idle outputs.
muythaibxr
Postby braineack » Sat Jun 09, 2012 5:58 pm
James,
BIG Thanks !!!
wd
y8s and I need this firmware as well. Ken could you email it me when you see this?
1991 Boosted Miata Running MS3 + MSX w/Full Seq.
http://gallery.boostedmiata.com
braineack
Postby y8s » Sat Jun 09, 2012 6:14 pm
James,
BIG Thanks !!!
wd
For what it's worth, Braineack and I seem to have mystery AC failures recently. Mind sharing the test code or letting us know when the magical fix of beta25 will show up? :)
y8s
Postby muythaibxr » Sun Jun 10, 2012 5:25 am
The issue that is fixed here only has to do with the TPS shutoff work. What problem are you experiencing exactly?
muythaibxr
Postby braineack » Sun Jun 10, 2012 6:06 am
When I went from alpha 11 to beta 22 the day i took my car out of winter slumber. my a/c seemed to only blow hot air, didn't ever think it was a firmware issue, it was fine in Oct when I parked it, but I figured maybe after sitting all winter it just slowly decharged. In fact I was about to go get my a/c recharged today, but have since decided to wait. I have my TPS off at > 75% and hysteresis 10%. The compressor appears to load up, but the clutch isn't engaging...which is odd cause I'd think my pressure switch would prevent that.
Y8s has had his car parked forever and parked it just after loading beta 22 as well, the other day he had to move it and suddenly his a/c isn't running. Very similar symptoms, a/c fan turns on, his pressure switch isn't to blame, compressor appears to put load on the engine, but the clutch isn't engaging to compress the r-123. He can get it to run if he jumps some wires to the compressor directly IIRC.
braineack
Postby muythaibxr » Sun Jun 10, 2012 2:01 pm
How long did you wait after starting? The code I added to delay AC engagement after it shuts off also delays AC engagement after start.
muythaibxr
Postby whittlebeast » Sun Jun 10, 2012 2:48 pm
The 25 beta code allows you to assign the primary fuel load as Speed-Density. If you then activate the MAF and choose MAFMAP as the secondary fuel load the code freezes on boot up. The error message is
Is there any possibility of getting the next beta code to allow this as an option? I think I can pull off everything I need to, with this option.
Andy
Sea-Doo 785 running MAF, V3 & Extra
whittlebeast
Postby braineack » Mon Jun 11, 2012 5:42 am
muythaibxr wrote:How long did you wait after starting? The code I added to delay AC engagement after it shuts off also delays AC engagement after start.
I reread his issue (I was playing video games and trying to read) and see it was just about the TPS% and intial engagement. My clutch is activating, so it seems I really am just low on freon. Disregard. Y8s seems to have a different issue.
FWIW, beta24 is running well on my miata. I like the CL activating for timing advance.
braineack
Postby y8s » Mon Jun 11, 2012 5:58 am
I let the car idle for a few minutes. compressor never kicked on.
y8s
Postby muythaibxr » Mon Jun 11, 2012 9:39 am
Send me your msq and a log. Mark the log with where you push the AC button.
muythaibxr
Next
Return to MS3 Development
