bad RPM single
Waiy
bad RPM single
Post by Waiy »
Hi
I got a problem with RPM single. I want to use fuel only. And I had try connected MS to coil negative and distributor, but they got bad single, both. Both of them give single are over 10k RPM while the engine first cranking, so I still can't start my car. Is anyway to reduce the single. Or put any resistor between MS and sensor?
Thx
