V3.0 MS3X for Nissan VK56 V8 setup help
General support questions and announcements for MS3. See also www.ms3efi.com for MS3 information
Re: V3.0 MS3X for Nissan VK56 V8 setup help
Postby billr » Sun Apr 22, 2012 4:37 pm
James, you know far better than I ever will, of course, but help me try to understand. Is the reason it can't run waste-spark and semi-sequential because it is a 36-2 wheel instead of a 36-1 presently supported in the code?
billr
Postby jsmcortina » Mon Apr 23, 2012 2:53 am
It is a 36-1-1 (the -1 teeth are opposite not adjacent.)
I'm pretty sure there's no way to run the existing code with that wheel only as it is.
I can supply, repair or upgrade Megasquirts in UK.
Postby billr » Mon Apr 23, 2012 8:42 am
OK, thanks. That I can sure understand. I saw before that it was called "36-1-1", but couldn't see two separate missing teeth in the posted tooth trace; that's why I wanted to see a trace with one rev spread out.
Edit: Oops, I went back and looked at the trace. I had never counted the pulses there before, just figured each gap is one revolution. It's pretty obvious where the two missing teeth are!
Edit2: And I can see how that pattern is pretty impossible to use without a cam sensor!
billr
Postby sjl008 » Mon Apr 23, 2012 4:56 pm
billr wrote:OK, thanks. That I can sure understand. I saw before that it was called "36-1-1", but couldn't see two separate missing teeth in the posted tooth trace; that's why I wanted to see a trace with one rev spread out.
The engine is the same as the LS1 just have to swap the firing order 3~2 around, and time the existing QR35DE, or QR25DE cam pattern to mate with this crank and were set. (As James mentioned in an earlier post):
by jsmcortina » Fri Mar 30, 2012 12:21 pm
Is that not a QR35DE wheel pattern? That's an existing option.
But
I'm sure going to try today to get a "Legitimate" composite log for him to use....
My Signature: google Henry Ford's quotes ;)
sjl008
Location: 'round the clock-'round the world. 127.0.0.1 mostly....
Postby sjl008 » Mon Apr 23, 2012 5:08 pm
But
sjl008
Postby jsmcortina » Mon Apr 23, 2012 6:44 pm
sjl008 wrote:The engine is the same as the LS1
How does it resemble the LS1 aside from being a V8?
It uses totally different crank and cam patterns!
Postby sjl008 » Mon Apr 23, 2012 8:15 pm
I stand corrected, the LS1 is 90* i think, and the VK is 60* (Off the top of my head.) anyway, the cam pattern might be used (the script) with some adjustments. My previous posts example the differences between the 2 motors more clear. For a brief moment I thought by simply manipulating the codes from both it would simplify.....nevermind.how do I delete a stupid post.....DOE!!!
sjl008
Postby jsmcortina » Tue Apr 24, 2012 1:47 am
Just because two engines have the same number of cylinders doesn't have any impact on the wheel decoder!
The LS and VK engines are totally different as far as decoding goes.
Postby billr » Tue Apr 24, 2012 9:36 am
Please forgive me for inserting this question, but it has been bugging me since I saw the cam trigger pattern, towards the beginning of this thread:
Since a 36-1 or 60-2 type of crank wheel and simple "half moon" cam/dizzy wheel will give all the info needed for full sequential/COP, what is the attraction to all the other patterns; is it just a matter of getting around someone else's patent?
billr
Postby jsmcortina » Tue Apr 24, 2012 9:46 am
For the OEMs you mean? I also don't know why there are SO many re-inventions of the wheel.
A half-moon cam wheel isn't great for VVT (although it could work) but the VW/LS2 cam pattern does the job simply and effectively.
Postby billr » Tue Apr 24, 2012 10:32 am
Ah, VVT... I wasn't thinking about that; now I see some need for more than "half moon" and polling on the cam.
billr
Postby sjl008 » Wed Apr 25, 2012 6:38 pm
see attached Logfiles, there are both cam n crank patterns.... nice n clean in the composite logger .csv
I tryed hard for 10 hrs to get them both on the same screen. I will try another laptop with TS and see if thats the difference. Now, with my 'oscope', I am seeing hysterious in the cam pattern. I have configured the TS & burned tune for many different types and still wind up using Log crank & Cam setting. I rarely get to see the pattern on the screen. My laptop is xp w/1g AMDcpu/ 1g ram; and it works great with all other programs including....uhghuuum,motec.
I will be checking my email today because hotels are expensive here and I want to get enough data to produce a decoder for this, so help if you can.
I will also try my other laptop w/ TS (Both r lic. to me) to see if thats an issue. ALL updated firmware, and .ini for TS so is there another reason why its not showing cam/crANK TOGETHeR? hint- signal is from EXTRA board, and cannot tune out hysterious with the superSmall trim pots either.......odd.
If you need a visual of both accurately super-imposed, I can P'shop it up; but, I believe you're more interested in the trigger numbers in the .csv for your script...
p.s.- clock is set corretly ;)
2012-04-25_13.36.09.csv
Clean crank pattern
(62.28 KiB) Downloaded 14 times
2012-04-25_14.57.43.csv
Clean Cam Pattern
(30.23 KiB) Downloaded 16 times
sjl008
Postby dieselgeek » Thu Apr 26, 2012 8:19 am
Any thoughts of simply mounting an external trigger wheel and cam pickup instead of working through another wheel? (although would be nice to see this engine added to the fold).
You should be able to rig something up simply enough that would let you get to the tuning part.
Squirted: it's easier to list the ones I haven't squirted. I need to do more motorcycle engines!
dieselgeek
Postby sjl008 » Thu Apr 26, 2012 9:15 am
dieselgeek wrote:Any thoughts of simply mounting an external trigger wheel and cam pickup instead of working through another wheel? (although would be nice to see this engine added to the fold).
You read my mind!!!
Any ideas? I pulled the extra board off today so I don't deal w/ the cam- now its a matter of config. for wasted COPs, bank inj. for 8 port injectors, and whats next? I had my eyes on a RX-8 11 tooth trigger wheel I saw i GUY mount on a VK56 (V8 5.6L DOHC) that looked dooable. He said His description stated he redrilled for the VK motor.
Does the rx-8 SET-UP sound good? Mr. cortina?
sjl008
Postby jsmcortina » Thu Apr 26, 2012 9:24 am
Just use a regular 36-1 wheel. The RX8 is another weird pattern.
Postby dieselgeek » Thu Apr 26, 2012 10:18 am
36-1 and figure out a 1-tooth cam signal, you'll have sequential spark and injection - all the best features of MS3X. Piece of cake!
dieselgeek
Postby sjl008 » Fri Apr 27, 2012 12:09 pm
dieselgeek wrote:36-1 and figure out a 1-tooth cam signal, you'll have sequential spark and injection - all the best features of MS3X. Piece of cake!
So, if I just go with a 'front crank mounted Trigger Wheel' ( say 36-1) and follow the instructions here I can have full sequential injection with wasted COP ignition????? please tell me it's true.
:o
If so, I can re-install the MSextra board for the sequential injection! ( btw- My 3 lights never come on on the MS3 unit, just sometimes blink once real quick; my other MS3 w/daughtercard works fine.... curious)
:RTFM:
sjl008
Postby racingmini_mtl » Fri Apr 27, 2012 12:16 pm
To have full sequential injection requires a cam signal as mentioned by Scott (dieselgeek). With only a crank signal, you can have semi-sequential injection (similar to wasted spark ignition). And this is mentioned in the manual page you linked.
racingmini_mtl
Postby sjl008 » Sat Apr 28, 2012 12:13 am
racingmini_mtl wrote:To have full sequential injection requires a cam signal as mentioned by Scott (dieselgeek). With only a crank signal, you can have semi-sequential injection (similar to wasted spark ignition). And this is mentioned in the manual page you linked.
Thanks Jean,
This first timers missing a lot, but getting there. So, I can setup wasted COP with the extra board in place but having a V8 using 2 4/5 wire igniters is cool?
Because Im not stateside, I have to make it. So, I am fashioning a168mm diameter 36-1 wheel with the teeth evenly spaced 50%/50% tooth space tooth space.... Thats how they looked in some pics I saw. Will this work? using different VR sensor as well.
sjl008
Postby jsmcortina » Sat Apr 28, 2012 2:23 am
(We could still get this working on the stock wheels.)
In MS3 there is an option for "wasted COP" which lets you wire up a set of COPs (one per cylinder) and the code fires them in pairs. That acts as an upgrade path for sequential - all the wiring is there ready for when you add the cam sensor.
PreviousNext
Return to MS3 General Support
