Ok, I'll attach the .msq and a log of whats going on when the motor is hot.. It starts and runs GREAT when cold, up to 4k rpm (Engine is in break-in period) .. As soon as it's hot, I can shut the car off, and it will not start up.. I did a composite log and trigger log and a tooth logger, seems very odd. There is ZERO triggers (from the cam, single tooth, rear sensor) The Tooth logger also looks off from when it's first starting.
The car runs great, doesn't shut off, but when I shut it off and try to restart, there's no cam signal.. It's confusing me a bit.
MS3X on a 2006 Nissan 350Z with a 2JZGTE swapped in.
Running on crank sensor and cam sensor, tooth#1 angle is 17, timing is spot on..
The cranking pulse may be a little weird when it's hot, seemed like it was cranking lean, so I added fuel, then realized it was the cam sensor.
