I just had a question that I hope someone can help with, for my car year I believe I need to do a fuel pump mod so I have a relay to control my fuel pump, as at the moment the fuel pump is controlled by the AFM and I'll be doing away with that.
I've been reading through this mod here which makes sense(kind of), but my main question is, it says to take power from S12c for the 12V supply but I've already jumpered S12c to JS9 as needed for my MS2 build. Can you jumper two 12v supplies to S12c or do I need to use another 12v supply now instead?
I've built my board based on this guide here but I won't be using an ICV and I'm going for the standalone harness.
Also a few other questions on this, in the text of that FP mod guide it says to use S12c, but then in the pic it has S19 but I can't see that anywhere on the board! Also it says to use R26 which I believe is a 1k resistor, whereas then above it it shows 2.2k!
So yeah I'm slightly confused as to what to do next, or even if there is a better way to control my fuel pump that doesn't involve doing that mod?!
Hope someone can help and apologies if this is in the wrong place or has already been discussed.
P.S. Also any tips on cleaning the board, I've already lightly scraped off the flux but just want to make sure it's clean before I try turning it on!
