Thanks for your help! I use PICKIT2 but i cant find anything to implement the config words?piubrazil wrote:Unfortunatelly, the source was made in pure assembly, and all the comments are in portuguese.
I don't know why the HEX didn't work for you. I use original PicStart plus from Microchip and good old MPlab 4.0 to write my PIC programs.
The configuration header of the source for pic:
processor 18F2620
#include "p18f2620.inc"
CONFIG OSC=HS, FCMEN=OFF, PWRT=ON, BOREN=ON, XINST=OFF, CCP2MX=PORTC, WDT=ON, WDTPS=8192, MCLRE=ON, PBADEN=OFF, LVP=OFF
__idlocs H'200000'
radix dec
Where must this be done? Is it possible to implement the config into the Hex file, or must this always be set manually?
For my understanding.....if you could implement the config into the code und export in mplab, the config would be implemented in the hex file
and there would be no need to set them at the burn process - or am i wrong
I´m sorry but i have never worked with Microchip only a little Arduino-programming...
Greatings Gerald
