BMW Crankshaft sensor
Hello,
I'm working on setting up a BMW V8 engine for megasquirt and I'm confused about the crank sensor type. It has two wires, but the BMW wiring info states that it is a hall effect type sensor. Has anyone seen a two wire hall effect sensor?
Thanks in advance
Thanks in advance
Re: BMW Crankshaft sensor
I have heard of 2-wire Hall sensors for industrial controls, it is certainly a possibility that yours is similar.
engine code, year, car model where it was originally?
Robert
MS3x 1.4.1 | TS 3.0.28
Thank you, the engine code is M62B44, it's from a 1998 BMW 540i.
This is where it's identified as a hall effect sensor. It shows the two connections and a shielded cable, but it's vague on the connection of the shield.
http://www.bmw-planet.com/diagrams/rele ... /index.htm
A VR sensor will give the same resistance reading regardless of which way round the DVM is connected, as it's a simple coil. A hall effect may give a resistance reading but will change with polarity as it's an active device.smalcol wrote:Hello,
Thanks in advance
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
MS2 V3
Tech Edge O2
London UK.
Simple enough, thanks so much!
im kinda a BMW guy
so let me fix it that all BMW M62 engine using VR sensor not Hall
sometimes even the VR sensor have 3 Pins.. it stills VR not Hall
because Hall is 3 pins.... VR usually 2 Pins
Pins Equal to Cable
Pins Equal to Cable
Pro Tuner and Racing Mgmt
Race Eng Mods, AWD Dyno Tuning, FI Specialist, Adv Diesel Tuning
Authorized Dealer of Dastek Unichip Central Java
Authorized Dealer of BoonDockers Indonesia
Certified Tuner of : Greddy, AEM, Haltech, Dastek, Ecushop
FB: victorgaragesmg@gmail.com
That seems to be correct, I measure the same resistance in both directions. The BMW documentation does refer to it as a Hall sensor, that's incorrect apparently.
i think ur manual guide is not offical from bmw
i am sure that m62 is mag / vr sensor
Some BMW did use a hall effect CPS. And they can fail. My M52 is on its third.smalcol wrote:That seems to be correct, I measure the same resistance in both directions. The BMW documentation does refer to it as a Hall sensor, that's incorrect apparently.
Another way to check a VR is to connect a DVM set to DC volts across it, and move a piece of steel across it - to mimic a toothed wheel. You should see a voltage. Which will change polarity if you move the steel in the opposite direction.
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
MS2 V3
Tech Edge O2
London UK.
