toyota camry sequential igniter 131300-2130 / 89621-33020
Postby gurov » Fri Jan 07, 2011 11:49 am
I am using this to drive 6 bmw coilpacks like so:
right side is input, left side is output. 12v is bypassed via red wire in the photos. inputs are straight from ms3x logic level, as if firing coils with builtin igniters. i swapped this as is with ls1 coils and it fired right up.
the 94-95 camry's all had the sequential ignitor and individual coils as did the 94-95 es300. anyway the part number on my ignitor is 131300-2130
That is actually a Denso #. The Toyota # is 89621-33020 or 89621-35011. Both may/should be on the tag on the ignitor.
89621-33020 is the 6-channel igniter used in the 94-95 Camry/ES300.
89621-35011 is a 3-channel igniter used in the 96 Camry/ES300 (and others).
Another choice is the actual 1JZ/2JZ 6-channel igniter, which was also used on the 95 Avalon, it has 2 connectors instead of just 1 like the Camry igniter.
1JZ/2JZ/1MZ 6-channel igniter can be one of the following numbers:
89620-14460
89620-24080
89621-22020
89621-22030
you can find the 131300-2130 / 89621-33020 igniter in the picture on ebay for 30 bucks or so a piece, connectors are a bit harder to come by.
same thing could be done with a toyota supra igniter, but it's way more expensive, cause its for a supra.
i'm looking for the pinout, seems that thread has disappeared, but i would be able to get the pinout from what i have set up there.
2004 BMW 325xi Turbo A/T MegaShift MS3/X M54B25 j&s slc_oem
1994 Toyota Supra Twin Turbo - AEM EMS v2 - 2JZ-GTE slc_oem
2004 Nissan SE-R SpecV Turbo - MS3/X QR25DE j&s slc_oem (SOLD !)
2012 BMW X3 35i MSport - single turbo N55 - stock!
gurov
Re: toyota camry sequential igniter 131300-2130 / 89621-3302
Postby gurov » Fri Jan 07, 2011 12:01 pm
here's some more pictures with pinout:
all the credit for this goes to this guy: http://www.cardomain.com/ride/2042690/1984-toyota-supra with an oldschool supra, and an MS2. some cool fab work there.
gurov
Postby gurov » Fri Jan 07, 2011 12:06 pm
one more thing. i have driven a CBR coil (aem pencil coil but WAY cheaper) with this igniter, but i'm not sure if the CBR coils need a special type of ignition setup (CDI ignition)
but they need special type of spark plug (one where the tip unscrews)
gurov
Postby gurov » Tue Feb 01, 2011 9:53 am
gurov wrote:one more thing. i have driven a CBR coil (aem pencil coil but WAY cheaper) with this igniter, but i'm not sure if the CBR coils need a special type of ignition setup (CDI ignition)
the cbr coils seem to work okay with the toyota igniter.
gurov
Postby dontz125 » Tue Feb 01, 2011 7:56 pm
Some bike pencil coils are CDI; some ('06+ Yamaha R6 - NOT R6S!) are TCI, and could be driven by BIPs.
dontz125
Postby BCM » Sun Feb 13, 2011 2:58 pm
Gurov -
What are the Part Numbers on those coils? I have some that look very similar, if not the same, that are Denso p/n 129700-4510 that I was planning on using with a Bosch 211 igniter (just finishing building extensions now). If they're the same - would you mind sharing the dwell settings you used and if you've had any issues with them?
Just started my MS2 to MS3/MS3X upgrade for my 4-Cyl BMW S14 this weekend...
Thanks,
Brendan
Brendan
My 1990 BMW E30 M3: viewtopic.php?f=104&t=40404
NA 2.3L 4-Cyl S14, MS3/MS3X, COP, Sequential
BCM
Postby gurov » Wed Feb 23, 2011 11:36 am
BCM wrote:Gurov -
Thanks,
Brendan
i've not had them on a running engine, but when testing, i set 3 ms dwell and things didn't get hot instantly. this was with the toyota igniter.
gurov
Postby Benz200t » Wed Feb 23, 2011 10:40 pm
Here's the pinout for the 1/2jz non VVTI ignitor.
Just sharing in case anyone needs it.
got the info from http://forums.hybridz.org/index.php/topic/76199-igniter-pinout-anyone-have-the-missing-info-from-this-pic/
Benz200t
Postby BCM » Mon Apr 25, 2011 9:09 am
gurov wrote:
BCM wrote:Gurov -
Thanks,
Brendan
Re-visiting this and posting as an FYI. I am using Denso p/n 129700-4510 (pictures look exactly the same as posted above). Cranking Dwell 4.0ms, Max Dwell 2.5ms, and everything has been running fine so far.
Brendan
BCM
Postby kritip » Mon May 16, 2011 10:45 am
Do you know the dimensions of these?
Cheers,
Kristian
Constantly evolving;
4 cylinder n/a, 16v 1368cc Fiat Seicento
kritip
Postby DLV-Engineering » Sun Jan 22, 2012 9:48 am
Did you use this igniter to drive the BMW coils?
I"m looking to use this one on my 2002 530i with fuel sequential as well, just making sure I can drive my OEM coils with this. Thanks!
DLV-Engineering
Postby hypeboy » Sat Apr 14, 2012 12:03 am
all the credit for this goes to this guy: http://www.cardomain.com/ride/2042690/1984-toyota parts with an oldschool supra, and an MS2. some cool fab work there.
this guy is amazing, this guy is my savior. thank you very much this is what I really need :)
hypeboy
Return to OEM EFI Hardware
