Test rabbit
(Runs on MS2 and Microsquirt)
Test rabbit
Postby svenakela » Wed Dec 27, 2006 10:04 am
Guys,
I'm planning to run the MS2-Extra code from scratch, so if you need someone to test your implementation and documentation - I'm here! :)
I'm completing my MS in a week or two, so if there are any hardware changes I need to know pretty soon.
Regards,
Sven
svenakela
Postby jsmcortina » Wed Dec 27, 2006 11:56 am
Please let us know you install details, in particular tach signal source and ignition output.
Fuel wiring is the same as any other Megasquirt install.
I can supply, repair or upgrade Megasquirts in UK.
Postby svenakela » Thu Dec 28, 2006 2:39 am
James,
I'll make a summary of all my sensors for you soon. I have a Subaru EJ20, and will use as much as possible from the engine, planning to use the original crank sensor but with a new 36-1 wheel. I can stay with the Subaru wheel if there's working MS-code, but I have no problem with replacing it (I was already planning for a change).
The ignition is the original coil pack.
Anyway, I'll give you all the details after next visit in the garage.
The main reason for me to go with the Extra code is to avoid buying yet another thing to run the ignition.
Regards,
Sven
svenakela
Postby svenakela » Thu Dec 28, 2006 2:44 am
Sorry for replying to myself, but I noticed that my profile was missing. Got some info there.... :)
MS II v3. Subaru driven VW bay on its way: the bus blog
svenakela
Postby svenakela » Sat Dec 30, 2006 7:16 am
More hardware info and some pic's.
http://www.primenta.se/index.php?option ... &Itemid=51
Regards,
Sven
svenakela
Users browsing this forum: No registered users and 4 guests
