Greg G wrote:OK time to get this topic back on track with firmware development and not individual tuning issues![]()
While I already raved about the excellent effect of the oversampled and averaged TPS data on TPSdot, the addition of robs' moving anchor filter resulted in a flat noise-free TPSdot line, at 100 lag factor (no lag filter applied). It's so flat it's creepy. But it is very responsive to throttle movements. Should allow even finer tuning of AE. There are no spikes to cause false triggersCompare it to MAPdot, which has only the oversampling/averaging done, also at 100 lag factor, but no robs filter. Perhaps MAPdot can get the same treatment in the future?
robs wrote:Now that I'm back on deck, I'm very keen to try out the new MAP sampling combined with the moving anchor stuff. I don't think Grant has posted the source to this patch yet, so I'll apply my tweaks to the mainline.
gslender wrote:I'm thinking I might add the MAP moving anchor option too... do you have something you can send me with that code (or is it in a prior diff)... and I might bang this out soon.
pigga wrote:I would like to ask a question in this context. What do the experts think: I noticed, that with 60-2wheel I had slight "jitter" on the rpm signal that I had never seen with stock hall sensor inside the distributor (which is a 2-tooth wheel if you wanna see it that way).
So...should the RPM sliding window size be related to the number of teeth? A 60-2 tooth wheel needs larger window than a 36-1 wheel for instance? And a stock distributor as mentioned above needs no RPM smoothing at all?
I am supposing this because the higher the number of teeth the more often the RPM signal will be updated. Am I thinking into the right direction?
robs wrote:If you're up for it, a while before I started the "Noisy" tpsDOT thread, I bored people silly with a "Noisy" RPM thread: http://www.msextra.com/forums/viewtopic.php?f=91&t=39155. It's a real page turner!
gslender wrote:Interesting read.
pigga wrote:Hi.
Probably a bit OT at this point, but yesterday I wondered if those Lockout-Settings are still active when I switch CL idle to "Use initial value table"?
Thomas
ol boy wrote:I got this version code loaded yesterday and I noticed today I was slightly rich across the hole VE table. I had turned on the MAP sampling for "lowest value". What does this actually do? I still have a MAP sampling window of 20* angle at a 10* sampling wide window. I thought I read through all 4 pages of this thread and the release notes posted on the first page but hadn't seen any explanation of how it works. I liked the sliding windows, in V2.3 alot. This versions works well without any changes to the tune. I flashed this version, reloaded the .msq, cleared the few errors with the previous .ini file, fired it up and drove to school without changing a thing.
Thanks Ryan
gslender wrote:Not sure what you mean, but PID Lockout-Settings tied to "Use initial value table" - so yes they are active, but at the time idle code is applying the initial value table, the use of lockout settings has past (as it has determined the IAC needs to be reset to an initial value ready for CL PID to control idle again).
Thanks Ryan
Perkele wrote:Only one thing I don't seem to fully understand is the dashpot decay.
My dashpot adder is 4.3% and decay is 10 and I'm using the IVT table.
But it doesn't seem to work as planned as you can see in the picture, it does add the dashpot adder but it drops back to IVT value right after. And most of the time it doesn't add the adder att all.
