why aren't EAE adhere and suck tables like ve?????????????
(Runs on MS2 and Microsquirt)
Postby weeblebiker » Thu May 10, 2012 8:00 pm
really
if the rational is to model the fuel pool on the walls which varies in size depending on load and rpm (like ve), why isn't both adhere to walls constant and sucked from walls constant set up as a load vs rpm with the constant as the z axis variable like ve is set up to better depict how much fuel is being added or sucked from the walls?
the constant vs temp can still be a graph like warm up is.
I don't see how two graphs can accurately model how much fuel is being added or subtracted to the walls, isn't this why two graphs are not used to calculate how much fuel needs to make it into the combustion chamber?
so why is eae set up with graphs and not tables?
'87 VW scirocco 2L 16V, TD0-14T 11:1 comp E85
v2.2 box, ms2, flyback, boost duty, isv, ignition out circuit
weeblebiker
Postby muythaibxr » Thu May 10, 2012 8:18 pm
Because all the research I did showed that only curves are necessary. Also, X-tau started out as a large table and a constant and it was nearly untunable. Later it was made similar to what we have with EAE with the 6 curves.
muythaibxr
Re: why aren't EAE adhere and suck tables like ve???????????
Postby Peter Florance » Fri May 11, 2012 2:56 am
muythaibxr wrote: Also, X-tau started out as a large table and a constant and it was nearly untunable.
True, I have the T-shirt to prove it. :)
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
Check your grounds: http://www.msextra.com/doc/general/grounding.html
Peter Florance
Postby weeblebiker » Fri May 11, 2012 5:36 am
I was thinking individual tables for adhere and for suck.
my setup seems to be more affected by air flow (rpm graph) than by tps positon (load graph) on mild to moderate and the divergence is greater at lower rpm and the difference between low rpm parking lot cruise (relativley stable fuel pooling) and decellerating to a lower cruise rpm/load from higher rpm/load (all the fuel sucked off) is wildly different. I've been trying to set up the eae the standard way and havent been able to get anything reasonable under 2500-3000rpm.
This is because the fuel injectors are in the itb injector location which is 3" up stream from the origenal location of the injectors, there is also a vacuum rail for the brake booster down stream from the injectors.
planning on changing my stratagy
setting up the load base graphs at 3k rpm and straight lining both load atx and sfw graphs then adjusting the rpm atw and sfw before adjusting the load atw and sfw.
don't suppose we could get a rpm range or limit on the regular ae? to turn it off say above 2000 rpm? be able to use ae as a low rpm assist without it buggering with eae up in the driving rpms.
weeblebiker
Postby Peter Florance » Fri May 11, 2012 5:39 am
Doesn't it do that now?
Peter Florance
PF Tuning
Peter Florance
Postby weeblebiker » Fri May 11, 2012 7:12 am
If it does where is the limiting rpm field located?
my understanding is that both ae and eae is always on but ae is disabled for low to moderate acceleration by entering a high threshold; making ae usable for slamming the throttle open. but enter a low ae threshold and ae buggers with eae.
the one known solution for this issue with itbs is to build a manifold with fuel injectors as close as possible to the intake valves and further from the throttle plates.
weeblebiker
Postby Peter Florance » Fri May 11, 2012 7:28 am
weeblebiker wrote:If it does where is the limiting rpm field located?
In AE there are two rpm points; one where taper starts and one where it ends (AE=0% of AE table entry)
I wrote part of those docs so I'm pretty sure you'll find it here:
http://www.msextra.com/doc/ms2extra/MS2-Extra_Tuning_Manual.html#accel
Peter Florance
PF Tuning
Peter Florance
Postby weeblebiker » Fri May 11, 2012 8:21 am
I ASSUMED those 2 rpm points were used to range both ae and eae since they are in the select window and not in the ae wizard.
weeblebiker
Postby Peter Florance » Fri May 11, 2012 8:46 am
weeblebiker wrote:I ASSUMED those 2 rpm points were used to range both ae and eae since they are in the select window and not in the ae wizard.
I don't think so but Ken would have to verify.
I think EAE works all the time by the curves only because it works from a model
Peter Florance
PF Tuning
Peter Florance
Postby muythaibxr » Fri May 11, 2012 9:19 am
EAE works all the time. Normal AE and the new accel pump AE work according to the RPM limits.
muythaibxr
Postby weeblebiker » Fri May 11, 2012 9:50 am
will accel pump ae be backported from ms3?
weeblebiker
Postby muythaibxr » Fri May 11, 2012 10:28 am
should already be though I need to backport some fixes we made as well.
muythaibxr
Postby weeblebiker » Fri May 11, 2012 10:51 am
one last but important question.
what is the hierarchy of ve,ae, eae and accel pump ae as they affect injector pulse width?
weeblebiker
Postby Matt Cramer » Fri May 11, 2012 11:37 am
weeblebiker wrote:one last but important question.
VE generates the main pulse width.
EAE uses the VE table for some of its calculations.
EAE and AE are both added. EAE also uses the fuel added by regular AE for its calculations.
The accelerator pump setting is an alternative to regular AE.
Postby gslender » Fri May 11, 2012 2:33 pm
muythaibxr wrote:should already be though I need to backport some fixes we made as well.
Nah, don't think that happened.... Remember the problem I had with memory and trying to get the new AE pump code to work in a new ppage.... Caused all sorts of issues.
Would love to see it working though.
G
Mazda MX5 91 NA6 LE | M45 Mini SC | 4-2-1 Extractors & HI-Flow Exhaust | HSD HR Coilovers | MS2 DIYPNP Full Seq running ms2extra pre3.3alpha5 gslender v2.8 | Toyota COP | RX8 425cc Inj | W2A Intercooled
gslender
Postby muythaibxr » Fri May 11, 2012 3:09 pm
No I must have forgotten about that. I will have to help you then. No problem :)
muythaibxr
Postby weeblebiker » Fri May 11, 2012 6:34 pm
so
eae(ve + ae) or ve+eae(ve)+ae+eae(ae) ?
your statement was kinda circular so I'm still unshure.
don't really need to know the transformation math, just the which algorithum affects which
weeblebiker
Postby muythaibxr » Sat May 12, 2012 5:40 am
ve+ae +eae(ve + ae)
muythaibxr
Postby weeblebiker » Sat May 12, 2012 4:29 pm
thanks!
weeblebiker
