Concerns over the air density correction calcs
(Runs on MS2 and Microsquirt)
gslender
Post by gslender »
Was looking at the code in MS2 and me thinks I've found a bug in the air density correction code...
There is a cast to an unsigned char (ccor) when in the cor calc above it could be less than 100 and therefore "cor - 100" could be -3 and when cast to unsigned char this would be a bad/incorrect value yeah? Even worse, the sign from the previous calc is also lost by making it unsigned.
Code: Select all
int aircor_eq(int mat)
    signed int cor;
    signed char ccor;
    // returns air density correction from equation in % (100 is no correction)
... <snip> ....
        cor = 529700 / (mat + 4597);
// Changed for 3.0.3w to ignore this (unused) setting always use degF internally.
//    else  {                          // deg C
//        cor = 293200 / (mat + 2732);
    if (flash5.airden_scaling) { // only if non-zero
        ccor = (unsigned char)cor - 100;    /// <<<<<<< this shouldn't be cast to an unsigned char !!!
        cor = ((signed int)(ccor * flash5.airden_scaling)) / 100;
        cor = cor + 100;
    return (int)cor;
Mazda MX5 + MS3 Pro
Peter Florance
Re: Bug found in air density correction
Post by Peter Florance »
subscribed to topic
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
Zaphod
Post by Zaphod »
Are the MS2 and MS3 MAT corrections the same?
fun is not a straight line
Sven
gslender
Post by gslender »
Source for the very latest ms3 code isn't released, so can't say, but a lot of the code often is similar.
Mazda MX5 + MS3 Pro
Peter Florance
What are the implications? Is it something I can check in a log?
Thanks!
Peter Florance
PF Tuning
Post by jsmcortina »
gslender wrote:There is a cast to an unsigned char (ccor) when in the cor calc above it could be less than 100 and therefore "cor - 100" could be -3 and when cast to unsigned char this would be a bad/incorrect value yeah?
The cast is on the _input_ to, not the output from that calc. (EDIT: Although at a glance I'm not sure why I added that cast.)
The previous calc is a positive number divided by a positive number - how can that give a negative result?
Have you checked the generated assembler for this code?
Have you tested it to see what range of values are produced?
gslender
Post by gslender »
Ahhh, true - precedence says the cast happens first, then the subtraction... good point. My bad. :oops:
Mazda MX5 + MS3 Pro
gslender
Re: Concerns over the air density correction calcs
Post by gslender »
Thought I'd share what the values do so that you can see for youself how the code impacts fueling based on tempature and the various % in correction scaling.
The fueling is scaled by the % calculated in the last two columns (one is for 100% MAT scaling, the other is values used at 50% MAT scaling).
I'll admit I was quick to think a bug exists when in fact the odd unsigned cast through my thinking around precedence.
I am now wondering if the lack of resolution makes any difference - note how the band of no correction (shown around 68-70F where it is at 100% correction) is only a small area as you change from 100% to 50% MAT scaling. When you look at 32F, the resulting correction is more pronounced (perhaps as it should be), but should the change to scaling have no impact to the correction seen at 64F deg, which is 1% additional fuel regardless of whether you have 100% scaling or 50% scaling? That seems wrong yeah? but perhaps the resulting fuel difference is negligble too... in which case when does it have an impact?
Code: Select all
F	C	100% 	50%
		Corr	Corr
32	0	108	104
36	2	107	103
40	4	106	103
44	7	105	103
48	9	104	102
52	11	104	102
56	13	103	101
60	16	102	101
64	18	101	101
68	20	100	100
72	22	100	100
76	24	99	99
80	27	98	99
84	29	97	99
88	31	97	98
92	33	96	98
96	36	95	98
100	38	95	97
104	40	94	97
108	42	93	97
112	44	93	96
116	47	92	96
120	49	91	96
Mazda MX5 + MS3 Pro
ol boy
Post by ol boy »
I'm glad you did this table. I can now see the % of change in the curve. I've changed my ini file to allow lower than 50% scaling, I run mine down around 20% and use the correction table to fine tune. I think heat soak issues are causing rough starts and poor running after a hot start. It's getting warm in southern AZ. 108*F tomorrow.
In MS3 we already changed the 'correction' curve to 0.1% steps. In a future code release we'll likely merge the built-in calculation and the correction curve.
gslender
Post by gslender »
Cool. Looks like a fairly easy thing to do... any problems if I give that a crack?
Mazda MX5 + MS3 Pro
aaronc7
Post by aaronc7 »
any progress? :)
gslender
Post by gslender »
Well I was hoping I'd get a blessing first, so I might look into it, but alas would prefer Ken or James to be ok with that first.
G
Mazda MX5 + MS3 Pro
muythaibxr
Post by muythaibxr »
I'm OK with it, just watch for overflows.
robd
Post by robd »
I'd be very keen to try out a new code with this change in it for MS2. :)
gslender
Post by gslender »
Ok, I've got a build I'm testing right now. Shouldn't be too much longer 8)
G
Mazda MX5 + MS3 Pro
aaronc7
Post by aaronc7 »
woohoo! Were you able to add any of the Air density correction taper features like I had mentioned? I've been looking into it on my own...but I am not a programmer, so it's going pretty slow. I've found it in the MS1 code and now looking to see how to incorporate that into MS2 existing code. But... if you're been working on it already then I suppose I'll just stop and wait!
gslender
Post by gslender »
aaronc7 wrote:woohoo! Were you able to add any of the Air density correction taper features like I had mentioned? I've been looking into it on my own...but I am not a programmer, so it's going pretty slow. I've found it in the MS1 code and now looking to see how to incorporate that into MS2 existing code. But... if you're been working on it already then I suppose I'll just stop and wait!
If you mean a RPM based taper, then yes.... I've extended the basic scaling to be 5 pt rpm based. Defaults to 100% like the single value scaler, but the curve can be changed to any % at any rpm so you can zero at idle 100% at 1000rpm sliding to zero at 4000 etc.
G
Mazda MX5 + MS3 Pro
aaronc7
Post by aaronc7 »
awesome, can't wait!
too bad my motor is still being built
