Seriously need some help :cry:
A general forum and a place for initial or prospective users. See MSExtra Documentation
Click here to enter
Contact a Forum Administrator
Postby mad4x4 » Mon May 28, 2012 12:06 am
Ok, installed mega squirt about 18months ago and car runs, but I just can't get the car to a point where it will meet UK MOT requirements . HC in the 1500 range and CO high as well
Car runs wil an over fuel black sooty exhaust and belteches balck smoke on throttle blips. :cry::cry::cry::cry:
Car is a 1.8 Zetec
Stock Injectors
LC-1 Wideband Lamdba
Ford Air Temp Sensor
Ford Modeo Crank Sensor
MS3 on board MAP
& GSRX750 TPS sensor onto GSXR Bike carbs. ( These have the slides locked up and are being used as throttle bodies)
Is there a Pay service or can any one help by either building me maps suitable or help my maps to a point the "auto tune" of Tuner studio will fix it. Can send out files I have currently if that helps.
Orginal MOT was in March it is now end of MAY - I'm going to miss the bloddy summer again :cry: :cry: Getting to the point I hat the "f'ing" car....
Car - MK Indy with 1.8 zetec Engine
mad4x4
Re: Seriously need some help :cry:
Postby jsmcortina » Mon May 28, 2012 3:16 am
Please post your MSQ and a datalog of startup and idling. Make sure the wideband is reading correctly in TunerStudio.
Excess HC typically means a misfire or MASSIVELY rich.
Excess CO means running too rich.
What do your spark plugs look like?
Black smoke on acceleration suggests your acceleration wizard numbers are too large.
I can supply, repair or upgrade Megasquirts in UK.
Postby mad4x4 » Mon May 28, 2012 4:16 am
Ok thanks - I'll get the logs and MSQ off of the lap top and post.
Andy
mad4x4
Postby Paddy » Thu Jun 07, 2012 5:40 am
I've got a 2.0 zetec & mine was running seriously rich when I first started it.
I found a page on megatune where you set the size of the engine & no of cylinders. Mine was set to 350 CID (which I took to be cubic inches) or 5.7 litres :shock: . I changed it to 2000cc & it ran better instantly.
Of course being a newbie to this I could have completely mis-interpreted it :lol:
Paddy
Paddy
Return to General, New users, Purchasing
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
