Going to run MS2 v3.0
Was told that the injectors to be wired in TWO banks.
Firing sequence is 1-5-4-8-6-3-7-2
Which injectors go to Bank 1 and which to Bank2?
Thanks in advance
efims wrote:By the way, what is maximum number of injectors (for each Bank) for MS2V3.0Series321?
If 4 injectors are too many(which can damage the ECU), what should I do(or add) in order that the ECU can run 4 Bosch injectors(taken from Mercedes M119) each bank without damaging(burning out) the MS2
Users browsing this forum: Bing [Bot] and 2 guests
