USB to TTL RS232 converter adapter board
Questions specific to Megatune. (Only about the tuning software, not about MS1/MS2 code or code features)
Note that Megatune is now obsolete.
Moderator: efahl
Postby ptegler » Sun Nov 12, 2006 9:47 pm
Hey guys and gals....
With all the talk of newer laptops not having comm ports anymore, and people needing USB connectivity...
Has anyone considered (or have tested) something like this!
check out ebay item # 160048055371 it's a small ckt board USB to ttl converter
How hard would you all think it would be to build one into the MS box directly?
ptegler
ptegler @ cablespeed.com
My Success story: http://www.msruns.com/viewtopic.php?t=21806
Home site: http://www.teglerizer.com/Injected_Spit6.htm
ptegler
Postby Matt Cramer » Mon Nov 13, 2006 10:10 am
We've built and tested a few USB Megasquirts, and have step by step directions on our website for how to set one up with the board we use:
http://www.diyautotune.com/catalog/dlpt ... p-141.html
This uses a slightly different circuit board than the one in the auction, but the idea's the same.
Postby floppy » Thu Jan 18, 2007 1:16 pm
Matt, i have installed the dlp-txrx and my computer recognizes it being there but it doesn't see it as a usb and wants a driver?
Thanks, mark
500 cubic inches, ms extra, 29v, 2.25,four 52# port injectors in an Auto-Nomics four barrel TB
floppy
Postby Matt Cramer » Fri Jan 19, 2007 9:46 am
Yes, it needs a VCP driver for this. Often this will install on its own with no trouble, but sometimes it doesn't. You can get the driver here:
VCP driver for Windows 2000 & XP
And you'll find the install guides at the bottom of this page.
Postby floppy » Fri Jan 19, 2007 9:49 am
Up and running!!! Thanks for the info. - Mark
floppy
Postby floppy » Sun Apr 01, 2007 8:25 pm
Has been working quite well and then started to hang. It will start when the motor is not running and will work for a couple of second upon startup or restart and then crashes. I initially thought that the only way to get it to come back online was to restart the PC but tonight I left it alone for an hour and it came back?. I have deleted and uninstalled all components several times to no avail, and re-burned the 029v firmware.
Started after I went to 029V but not right away, 029V actually made the jump to excellent running.
Just when I thought I had won????
Still runs well, which is good since It no longer cares to be tuned....
Thanks, Mark
floppy
Postby floppy » Sun Apr 01, 2007 9:37 pm
No change when using my wifes new laptop...
Tried to turn off write block in .ini and add a 50 writeblockdelay- no change
floppy
Postby neogenesis2004 » Sat Sep 08, 2007 11:59 am
bump for this problem, I have the diy internal usb converter also. Once the car starts megatune freezes every time without fail. I can't find a solution to this problem as of now.
neogenesis2004
Postby neogenesis2004 » Sat Sep 08, 2007 12:27 pm
I just decided to try it on megatunix and megatunix instead of locking up returns me this error.
1978. Error Opening "COM7", Error Code: No such file or directory
This is on a fresh firmware flash and everything. The converter "works", I can flash the ecu, and change settings on it. The moment the motor actually starts and is running though communications stops. So I can't tune the ms at all right now.
neogenesis2004
Postby richyvrlimited » Mon Sep 10, 2007 6:06 am
neogenesis2004 wrote:I just decided to try it on megatunix and megatunix instead of locking up returns me this error.
try checking all the connections at the ECU end. I had a comms issue and it turned out to be a dry joint on the RS232 serial comms chip (not USB I know).
that too seemed to deteriorate over time till in the end I couldn't see the MS.
2003 MX5. Coldside MP62
richyvrlimited
Return to Megatune
