Moderator: efahl
;Gauge Setup 0
gauge1 = RpmHiResGauge
gauge2 = afrGauge
gauge3 = voltMeter
gauge4 = dutyCycle1Gauge
gauge5 = VacBooGauge
gauge6 = matGauge
gauge7 = cltGauge
gauge8 = pulseWidth1Gauge
Rallyfinnen wrote:Great! I now have my own favorite setup every time i open MT!
Thanks!
djandruczyk wrote:Rallyfinnen wrote:Great! I now have my own favorite setup every time i open MT!
Thanks!
well, u can also try megatunix which has some pretty good looking photorealiastic gauges that are all configurable and layoutable via MTX's gaugedesigner and dashdesigner. The only downfall is that mtx does NBOT yet support MS2. (soon to change)
http://megatunix.sourceforge.net
DL instructions in my signature.
jacobrussell wrote:djandruczyk wrote:Rallyfinnen wrote:Great! I now have my own favorite setup every time i open MT!
Thanks!
i get a missing DLL error when i try and run it
missing libairo-2.dll
beige91 wrote:if you did that, and you have a way to put boost and vacuum on one gauge, plz post the code. thank you.
Asteris wrote:I don't see any combined boost/vacuum gauge like that on MSII extra.
It would be fairly easy to do, if config file could accept mathematical expressions like:
mapGauge = map -100, "Engine Vaccum/Boost", "kPa", -100, 150, -100, -20, 100, 140, 1, 0
or a way to define a new variable (let's say mrv=map-100) and use it instead of map on the above config line.
redmist1 wrote:I'm using a 7" VGA screen in my car and want to reduce the number of guages and make them bigger. I can delete guages in the ini file but "undefined" guages still apear in all the locations.
Pete
Did u follow the install instructions?
i.e. install the CORRECT GTK+ runtime
make sure GAIM is uninstalled if u have it
that error is most common if you forget to install the GTK+ runtime (which it tells you right in megatunix's installer), it can also appear if GAIM is installed which hoses GTK+ apps other than itself on windows.
