Lower connector is standard DB37, upper connector is MS3X. Map sensor port in hole at bottom.
Serial port, USB connection, SDcard in slot and 'spare' DB15.
racingmini_mtl wrote:I looks like the taller case is obtained through a couple of rails, one on each side. Is it a temporary solution with a one piece replacement top case half coming later or is it the final solution? Or am I not seeing it correctly?Jean
Una wrote:I love it. Just so long as it comes in black.
lumpensack2003 wrote:Una wrote:I love it. Just so long as it comes in black.
I used cases from extruded aluminum, black anodised, for different customer specific products.
After a while, I checked that scratches in the surface are *much* more disturbing looking.
So I changed to uncoloured anodisation - and am happy with it ...
Just my 2 Cts
Matt Cramer wrote:lumpensack2003 wrote:Una wrote:I love it. Just so long as it comes in black.
We'll most likely give you both options when we tool up for cases.
Users browsing this forum: old guy and 3 guests
