Tjabo wrote:Why would you do that when you can run it natively from the MS3X?
Also, the ability to PWM the nozzle with a consistent pressure as you can from the MS3X is vastly more mappable with good atomization. Confused I am! LoL...
Tjabo wrote:That last point is definitely a bonus! How cheaply do you think you'll be able to build the motor PWM controller then?
My only real reservation with this is that when running a good bit of methanol you really need some good mapability to cope with big temperature swings, and I don't know if volume adjustment via motor speed control can really do it without sacrificing a lot of atomization at the low end. Temp swings have been quite a pain for me, but right now I have no ability to compensate for it at all... I'll be very interested to see how this works out!
franksidebike wrote:Hallo
can the V3.0 Bank1/2 circuit a AME Water Pump handel?
in the AME Video she says the Pumpe have 6amp!
frank
Users browsing this forum: Rebellpntball and 2 guests
