E46 BMW M3
E46 BMW M3
Postby Abdula » Sun Apr 10, 2011 8:46 pm
Hey I am new to this forum and I have been scouring the net for days trying to find someone who has used megasquirt on a E46 BMW M3. I just got this car a month ago and have been looking for a good stand alone unit for it. A friend recommended ms to me but a lot of the BMW forums are suggesting Pectel. I was wondering if anyone had any input. Some of the common issues that I have seen have been in controlling the Vanos of the BMW's. the motor is the s54 motor 3.2L. thank you for any input :)
Abdula
Re: E46 BMW M3
Postby gurov » Tue Apr 12, 2011 9:19 am
my m54 runs on ms3 with vanos control, but the cam wheels on that are very simple.
s54 has two solenoids per cam one for advance one for retard, and the cam wheels are more complicated.
2004 BMW 325xi Turbo A/T MegaShift MS3/X M54B25 j&s slc_oem
1994 Toyota Supra Twin Turbo - AEM EMS v2 - 2JZ-GTE slc_oem
2004 Nissan SE-R SpecV Turbo - MS3/X QR25DE j&s slc_oem (SOLD !)
2012 BMW X3 35i MSport - single turbo N55 - stock!
gurov
Re: E46 BMW M3
Postby jsmcortina » Tue Apr 12, 2011 9:54 am
gurov wrote:s54 has two solenoids per cam one for advance one for retard, and the cam wheels are more complicated.
Do you have any technical data on what the cams are like and how the solenoids should be controlled ?
The alpha code attempts to control the 4 cam V10 motor with its funky cam patterns.
Re: E46 BMW M3
Postby AbatelliCristian » Sat Apr 16, 2011 12:10 am
I have bmw e46 320 with 2 vanos. I have ms3+msx and vanos is perfect. I use on-off signal for solenoid. I configure injector G-H out for signal on-off vanos.
Is perfect.
AbatelliCristian
Re: E46 BMW M3
Postby gurov » Sun Apr 17, 2011 8:35 pm
AbatelliCristian wrote:I have bmw e46 320 with 2 vanos. I have ms3+msx and vanos is perfect. I use on-off signal for solenoid. I configure injector G-H out for signal on-off vanos.
Is perfect.
non M engines are way different on the cam signal plates. we have 50/50 crescent cam tooth, so that works out awesome. i'll try to find some infos about s54 cam plates.
gurov
Re: E46 BMW M3
Postby 16V-Sauger » Tue Jul 26, 2011 11:07 pm
Any updates?
kind regards
Nil
16V-Sauger
Re: E46 BMW M3
Postby hassmaschine » Wed Jul 27, 2011 6:53 am
I've been doing a lot of research on the S54 as I'm planning on going with it in a year or two.
what I've gathered:
the vanos solenoids vary from 120-210hz depending on their mode (higher rate for faster response, lower rate to prevent drift)
the intake cam wheel is an 8-1 with a hall sensor, exhaust cam wheel is 6 teeth with a hall sensor
crank sensor is 60-2 (typical for BMW), VR sensor, tooth #1 at 84 degrees (using the rising edge)**. probably a special decoder for the cam wheel will be needed.
Two things that are not currently implimented in the current MS3 VVT code are oil temp and the variable PWM frequency. it seems like both of these things could be applied to any car with VVT though.
James, what would you need for the cam wheels? do we need to know where the missing tooth is in respect to TDC? is knowing that it's an 8-1 wheel good enough?
for driving the two solenoids per cam - I'm thinking we could do something similar to what we used to do for 3 wire PWM IAC's, using the single fidle PWM output, to a driver board that split it out into two seperate channels (one push, one pull). then you'd only need the same 2 PWM channels and MS wouldn't need to know anything more. thoughts?
edit: something like this:
except the input would be one of the MS3x's PWMs instead of fidle.
**note: I've seen people use anywhere from 80-86 degrees for tooth #1. None of these angles could be correct - the teeth are each 6 degrees apart, there can be no tooth at 80 or 86 degrees. this goes from basic DTA systems all the way up to $$$ motec!
hassmaschine
Re: E46 BMW M3
Postby hassmaschine » Wed Jul 27, 2011 9:03 am
maybe this thread would be better off in the MS3 development forum?
hassmaschine
Re: E46 BMW M3
Postby hassmaschine » Fri Jul 29, 2011 9:32 am
working on getting some detailed cam wheel info from a couple different people. Don't have an engine in front of me to work with, unfortunately.
surely I'm not the only one still interested in this though?
does the V-10 have a similar pattern?
hassmaschine
Re: E46 BMW M3
Postby jsmcortina » Fri Jul 29, 2011 9:42 am
It would be really handy if the missing tooth on the cam aligned with the missing teeth on the crank on one phase and on the opposite phase there was a nice large cam tooth that covered the tooth#1,#2 region. Having different numbers of teeth on the different cams is a pain, but could be handled.
Re: E46 BMW M3
Postby hassmaschine » Fri Jul 29, 2011 10:28 am
alright, I'll do my best to find out exactly how it works :)
hassmaschine
Re: E46 BMW M3
Postby gurov » Fri Jul 29, 2011 11:28 am
hassmaschine wrote:working on getting some detailed cam wheel info from a couple different people. Don't have an engine in front of me to work with, unfortunately.
i'd be interested in this on the off chance that i swap an s54 into my 325xi
gurov
Re: E46 BMW M3
Postby howelll » Wed Aug 03, 2011 2:41 am
Another item to deal with on the s54 is the drive by wire, I beleive you can convert it to throttle cable with a kit from vac. Not sure if the s54 uses that with a tps or if the signal is sent from the peddle.
howelll
Re: E46 BMW M3
Postby hassmaschine » Wed Aug 03, 2011 6:05 am
you definitely need to eliminate DBW. MS3 could probably do it but I don't think they want to go there.
it has a TPS on the throttles as well
hassmaschine
Re: E46 BMW M3
Postby howelll » Wed Aug 03, 2011 9:47 pm
hassmaschine wrote:you definitely need to eliminate DBW. MS3 could probably do it but I don't think they want to go there.
Ah but whats the fun in that? I think its part of the fun of megasquirt, analyzing schematics until your ready to pull your hair out. But when you figure it out your like hell yeah! :yeah!:
howelll
Re: E46 BMW M3
Postby howelll » Wed Aug 03, 2011 9:56 pm
http://wds.spaghetticoder.org/en/svg/sp ... .svg?m=e46
looks like the dme takes a signal from the pedal position sensor then actuates the electronic throttle valve, here is how it works.
http://wds.spaghetticoder.org/en/zinfo/ ... EDKS62.htm
howelll
Re: E46 BMW M3
Postby hassmaschine » Thu Aug 04, 2011 5:59 am
yeah, it's not that difficult to figure out. But AFAIK, the MS developers don't want to add DBW to MS, so it's sorta moot..
hassmaschine
Re: E46 BMW M3
Postby prof315 » Thu Aug 04, 2011 9:36 am
hassmaschine wrote:yeah, it's not that difficult to figure out. But AFAIK, the MS developers don't want to add DBW to MS, so it's sorta moot..
The reluctance to add DBW to MS is because of liability issues. MS is not a multi-billion dollar corporation with platoons of scumbag lawers to protect their interests.
The Professor
92 Corrado 2.0L ABA on MS3Pro. Support the developers! Sandy Linfert 11/4/91- 5/13/13
prof315
Re: E46 BMW M3
Postby hassmaschine » Thu Aug 04, 2011 10:08 am
I wasn't making an argument for/against it. Merely stating a fact. :)
personally, I don't care - throttle cable works just fine for me. One less thing to tune on an engine that already has a laundry list of features..
hassmaschine
Re: E46 BMW M3
Postby howelll » Fri Aug 05, 2011 2:50 am
Looking at every thing the stock dme controls, Megasquirt in my opinion is a downgrade. The stock dme controls a lot of features including traction control, SMG, VANOS (reads two cam sensors), 3 knock sensors, emissions equipment, and drive by wire. Unless you’re making a race car that doesn't require all of those features you would loose a lot of them.
howelll
Next
Return to MS3 Development
