Do get it wright I should put a 100Ohm resistor betwin MS3X and BIPs base and I should connect the collector to the coil and the emitter to the ground. Correct?
Is this heat sink big enought?
LoukakIS wrote:Why the "ready light" on TS is off? Is it normal?
LoukakIS wrote:My MS3X injection outputs have 0V difference with the ground and 9V difference with the + of my car-battery. Is this normal?
I have the registered edition of TS and I used my key once on my laptop. Now I'm formatting the laptop and I also need to install the registered edition on my carpc. Will my registration key cover me
hassmaschine wrote:tooth #1 angle is always going to be a multiple of 6 when you have a 60-2 wheel, as a guide (each tooth is 6 degrees wide).
Users browsing this forum: binlki1 and 1 guest
