MS3X on BMW E36
Re: MS3X on BMW E36
Postby LoukakIS » Thu Oct 20, 2011 3:32 am
I will drive my coils from MS3X and I have two questions about the bips.
Do get it wright I should put a 100Ohm resistor betwin MS3X and BIPs base and I should connect the collector to the coil and the emitter to the ground. Correct?
Is this heat sink big enought?
LoukakIS
Re: MS3X on BMW E36
Postby LoukakIS » Fri Oct 21, 2011 8:22 am
Anyone?
LoukakIS
Re: MS3X on BMW E36
Postby Matt Cramer » Fri Oct 21, 2011 12:58 pm
That wiring should work.
Heat sink size depends on the location and how hard you drive the coils. It should be OK unless it's sunk into potting epoxy.
Re: MS3X on BMW E36
Postby LoukakIS » Fri Oct 21, 2011 2:57 pm
Nice, thanks Matt.
LoukakIS
Re: MS3X on BMW E36
Postby LoukakIS » Sun Oct 23, 2011 1:03 pm
I installed today my MS3 on my car again. The circuit with the BIPs worked fine but sometimes the timing light was flashing twice(one quick double flash). Is this normal?
But my problem isn't that. I was ready to check the timming and start the engine for fisrt time, but I stopped getting rpms! I checked everythink but while cranking I couldn't see any more rpms and also nothing on the tooth logger. I ckecked also my crank sensor.Is it any cofiguration that I possibly changed by mistake?What should i check?
LoukakIS
Re: MS3X on BMW E36
Postby LoukakIS » Mon Oct 24, 2011 1:54 am
Also the "ready" light on TS is "not ready". Any ideas, why I don't see the cranking?
LoukakIS
Re: MS3X on BMW E36
Postby jsmcortina » Mon Oct 24, 2011 1:56 am
Do you get anything in the composite logger? If not, then you most likely have an electrical problem.
Re: MS3X on BMW E36
Postby LoukakIS » Mon Oct 24, 2011 3:12 am
Nothing at all. I attached the csv file. I can't understand why this is happening, i never had this problem before. Should I install the OEM DME to check that the engine is working? Why the "ready light" on TS is off? Is it normal?
2011-10-24_13.00.20.csv
(20.18 KiB) Downloaded 14 times
LoukakIS
Re: MS3X on BMW E36
Postby LoukakIS » Mon Oct 24, 2011 3:42 am
I installed the OEM DME and the engine is working fine. I can't explain why is this happening with my MS3...
LoukakIS
Re: MS3X on BMW E36
Postby jsmcortina » Mon Oct 24, 2011 4:09 am
LoukakIS wrote:Why the "ready light" on TS is off? Is it normal?
It is normal if you do not have a tach signal.
Re: MS3X on BMW E36
Postby LoukakIS » Mon Oct 24, 2011 4:42 am
MANY thanks James, this info helped me a lot!!
The carnk sensor pin was broken in the adapter i made.
The double flashes in my timing light are normal? Some times the light flashes a single pulse and some others it makes a quick double flash.
LoukakIS
Re: MS3X on BMW E36
Postby LoukakIS » Mon Oct 24, 2011 12:08 pm
I tried to start my engine but nothing happened, because the injectors aren't injecting.I saw pulsewidths in TS(34ms on sequential and 17ms on semi-sequential).So I tried the test mode. The fuel pump worked and the coils also, but the injectors were dead. They are connected on 12V and MS3X(inj1-19,inj2-10,inj3-16,inj4-13)....
LoukakIS
Re: MS3X on BMW E36
Postby LoukakIS » Mon Oct 24, 2011 1:21 pm
My MS3X injection outputs have 0V difference with the ground and 9V difference with the + of my car-battery. Is this normal?
LoukakIS
Re: MS3X on BMW E36
Postby LoukakIS » Tue Oct 25, 2011 3:31 am
LoukakIS wrote:My MS3X injection outputs have 0V difference with the ground and 9V difference with the + of my car-battery. Is this normal?
WITH the injector connected I see 12V difference with the ground and 0V difference with the + of my car-battery. This sounds normal to me, isn't it?
LoukakIS
Re: MS3X on BMW E36
Postby LoukakIS » Tue Oct 25, 2011 4:00 am
I think I found where the problem was.
Do we have any configurations-maps for M42B18 engine to start with?
LoukakIS
Re: MS3X on BMW E36
Postby hassmaschine » Tue Oct 25, 2011 6:30 am
all you need for a "config" on a BMW engine is the right tooth #1 angle and a base ignition timing and fuel.
hassmaschine
Re: MS3X on BMW E36
Postby LoukakIS » Tue Oct 25, 2011 9:25 am
I put the #1 tooth angle 125* but I will take a better look with my timing light. It should be something between 114 and 130.
I have the registered edition of TS and I used my key once on my laptop. Now I'm formatting the laptop and I also need to install the registered edition on my carpc. Will my registration key cover me?
LoukakIS
Re: MS3X on BMW E36
Postby hassmaschine » Tue Oct 25, 2011 9:27 am
tooth #1 angle is always going to be a multiple of 6 when you have a 60-2 wheel, as a guide (each tooth is 6 degrees wide).
hassmaschine
Re: MS3X on BMW E36
Postby LT401Vette » Tue Oct 25, 2011 9:34 am
Yes, the agreement is for 1 user on up to 3 computers. So you should have a problem.
Re: MS3X on BMW E36
Postby jsmcortina » Tue Oct 25, 2011 9:38 am
hassmaschine wrote:tooth #1 angle is always going to be a multiple of 6 when you have a 60-2 wheel, as a guide (each tooth is 6 degrees wide).
Why's that? Tooth#1 angle is whatever is required to get correct timing. It depends on sensor and wheel phasing.
On my 36-1 wheel, the correct tooth#1 angle happens to be 39 degrees.
PreviousNext
Return to MS3 General Support
Users browsing this forum: Google [Bot] and 1 guest
