Noob ve table question. Values too high?
Postby anangryford67 » Tue Oct 25, 2011 11:50 am
So I got my idle consistent and started using autotune on ts. My car was running lean so it quickly started raising the values. At 2400 rpm and 94 kpa it has a values in the 130's and ramps up from there. It's a blown ford 302. Is that too high. What did I do wrong? I have the ve calc set at 13.7:1. I left the ae and ego on. Is that ok? Please help!
anangryford67
Re: Noob ve table question. Values too high?
Postby myk777 » Tue Oct 25, 2011 4:40 pm
The limit is 255 so anything below that works just fine, some people prefer larger numbers as it gives finer control.
Mike
myk777
Postby anangryford67 » Tue Oct 25, 2011 9:01 pm
Thank you!
anangryford67
Postby Matt Cramer » Wed Oct 26, 2011 5:41 am
I'd add that numbers over 100% are pretty common on supercharged applications to make a rich enough AFR.
Return to MS1/Extra support
Users browsing this forum: Bing [Bot] and 3 guests
