capacitor on +12v wire for ls cop wiring
General support questions and announcements for MS3. See also www.ms3efi.com for MS3 information
Postby turbo6man » Thu Dec 29, 2011 8:33 pm
I am going to wire in capacitors for my LS2 coils as per here: http://www.msextra.com/doc/ms3/ls1.html . I know they call for 1.0 uf Capacitors. My question is what type of capacitors do I want to use, ceramic, paper etc.? Do I need one per coil, one per bank of four, or one for all eight? Can I wire them halfway from the ms3 ecm to the cop (this would cleanly put them on a board under the dash) or do they have to be out in the engine compartment at the cop
turbo6man
Re: capacitor on +12v wire for ls cop wiring
Postby myk777 » Thu Dec 29, 2011 10:18 pm
Mylar/Film caps, I used one per bank on my v8 close to the coils.
Mike
myk777
Postby aarc240 » Fri Dec 30, 2011 12:31 am
Use ceramic capacitors, placed as close to the coil as possible.
If anyone is already using mylar film caps in the engine bay, plan on replacing them regularly or switching to ceramic capacitors.
Mylar film capacitors have a rated life of 1,000 hours at 105 degrees, 30,000 hours at 40 degrees (both Celsius) and the characteristic curve is nothing like linear.
By 50 degrees the rated life shortens by nearly 40%.
As the engine bay can easily reach 65 degrees on a cool day and much more on a summer stinker, mylar film caps don't have a good life expectancy.
Hopefully, this might save someone some head scratching down the line :D
Art,
Datsun 260z 2/2 with 280z/MS3+/5spd for the road
Datsun 240z with 280z - broken
Nissan E24 Urvan with 260z/Megajolt/5spd parts hauler
aarc240
Postby SymTech Laboratories » Fri Dec 30, 2011 2:44 am
Ceramic capacitors are certainly the best choice for this application. Be sure you select capacitors with an appropriate voltage rating (at least 22V for 12V automotive systems).
Bypass capacitors, such as these, work best when physically located as close to the device as possible. Ideally, you should install one per coil.
Postby Peter Florance » Fri Dec 30, 2011 4:36 am
Overkill, but I use Ford EDIS capacitors.
Easy mounting too.
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
Check your grounds: http://www.msextra.com/doc/general/grounding.html
Peter Florance
Postby preston » Fri Dec 30, 2011 2:53 pm
What are the potential problems with not using the capacitors ?
preston
Postby myk777 » Fri Dec 30, 2011 6:57 pm
aarc240 wrote:Use ceramic capacitors, placed as close to the coil as possible.
Here's the one's I used, they show an operating range up to 185deg F, seemed plenty for the wiring harness in my application. There's no life expectancy data, but I assumed if you stayed within the mfg operating temperature range they would have a very long life?
http://www.nteinc.com/capacitor_web/pdf/mlr.pdf
Mike
myk777
Postby turbo6man » Sat Dec 31, 2011 6:19 pm
Thank you everyone for the help.
turbo6man
Postby Ollie8974 » Sun Jan 01, 2012 8:15 am
Peter Florance wrote:Overkill, but I use Ford EDIS capacitors.
Easy mounting too.
Can you post a part number?
Ollie8974
Postby Peter Florance » Sun Jan 01, 2012 11:39 am
Easy mounting too.
It says F6AF-18801-AA on it
I think that is a Ford #
Peter Florance
PF Tuning
Peter Florance
Postby Ollie8974 » Sun Jan 01, 2012 6:12 pm
Thanks, Peter
Ollie8974
Postby aarc240 » Sat Jan 07, 2012 6:36 am
@Mike
Right there in the data sheet "Life Test: 1000Hrs @ +85°C (+185°F) at 150% rated voltage"
Not pushing them to their voltage limits will certainly extend the life but all the test data I've seen indicates by no more than x2.
I'll second those thanks Peter.
Art,
aarc240
Postby myk777 » Sat Jan 07, 2012 3:22 pm
aarc240 wrote:@Mike
You must have missed this post:
viewtopic.php?f=132&t=43528#p307625
From what I found its more like a factor of 157x....157,000hrs is plenty for me.
Mike
myk777
Postby Peter Florance » Sat Jan 07, 2012 3:36 pm
Here's a photo of the cap mounted on LS2 coil
wow, I needed to clean my bench that day...
Peter Florance
PF Tuning
Peter Florance
Postby Peter Florance » Sun Jan 08, 2012 5:58 pm
Also Mazda N3A1-66-991 (RX8) is similar.
Peter Florance
PF Tuning
Peter Florance
Postby turbo6man » Sun Jan 08, 2012 8:37 pm
Thanks I went to my local wrecking yard and they have a bunch of them and they sold them to me for $3.99 a piece. I bought 4 and I think I will set it up with one per two coils and see how that works. If I have issues I will buy 4 more and put one on every coil. Just to be clear I will not hurt anything in the ecm, It may have a noise issue causing a sync or a misfire condition right?
turbo6man
Postby Peter Florance » Sun Jan 08, 2012 8:50 pm
turbo6man wrote:Thanks I went to my local wrecking yard and they have a bunch of them and they sold them to me for $3.99 a piece. I bought 4 and I think I will set it up with one per two coils and see how that works. If I have issues I will buy 4 more and put one on every coil. Just to be clear I will not hurt anything in the ecm, It may have a noise issue causing a sync or a misfire condition right?
I think there is no downside to using them.
2 per coil seems like plenty
Peter Florance
PF Tuning
Peter Florance
Postby MadDart » Wed Jan 11, 2012 2:28 am
Easy mounting too.
Where are you buying these at?? So you are saying that 1 per bank of 4 Coils is fine? Looks like there are 3 wires on these Capacitors. What wires go where? Looks like a ground, hot in and out of the Cap?
MadDart
Postby Peter Florance » Wed Jan 11, 2012 4:36 am
MadDart wrote:Where are you buying these at?? So you are saying that 1 per bank of 4 Coils is fine? Looks like there are 3 wires on these Capacitors. What wires go where? Looks like a ground, hot in and out of the Cap?
I'm using junkyard parts as I can't find the correct part #.
Single wire that attached to 12 volt line. The mounting bracket is the ground
Peter Florance
PF Tuning
Peter Florance
Postby turbo6man » Wed Jan 11, 2012 8:56 pm
I went to my local "Pick and Pull" wrecking yard and just started looking at the newer ford cars and I found an abundance of these and they had the same p# as Peter posted.
turbo6man
Next
Return to MS3 General Support
cron
