Voltage Spike 29Y4 MS1
Postby efims » Wed Jan 18, 2012 6:28 pm
Found voltage spike in Tunerstudio datalog....poor idling when air-con is energized.
Changed alternator from 90A to 120A, problem still there.
Added grounding cable from engine to body, cleaned grounding connection to ECU.
What did I missed out?
Datalog attached.
You do not have the required permissions to view the files attached to this post.
efims
Re: Voltage Spike 29Y4 MS1
Postby efims » Wed Jan 18, 2012 6:40 pm
I could not attach the datalog file cos it's too big
efims
Postby daxtojeiro » Thu Jan 19, 2012 3:46 am
Make a shorter log and also post the msq file.
Looks like noise, do you have at least 4 ground wires from the MS seperately running to the engine block?
Do you have resistive spark plugs?
Have you fitted a capacitor to the coil(s)?
See here for wiring help:
http://www.extraefi.co.uk/wiring_basics.html
http://www.extraefi.co.uk/resets.htm
Phil
manuals/MS_Extra_Manual_Index.htm for MS1 Extra Manuals
ms2extra/ for MS2-Extra Manuals
http://www.extraefi.co.uk/cobra/accobra.htm 5.0L TVR powered Cobra Replica (MSnS-E)
daxtojeiro
Postby HidRo » Thu Jan 19, 2012 4:04 am
I identified a problem with my car, which was the relay box.
14V was getting in, passing the relay, and when going out the relay box to the wire, it would pass only 13V.
So, whenever I turned the lights on, 0.5V would be removed, and if the fan kicked in, another 0.5V would be removed. In the end, I would see 11.8V in the logs.
Check wiring for voltage drops.
HidRo
Postby efims » Thu Jan 19, 2012 6:21 pm
Attached below MSG and Datalog
Ran another cable from Alternator to Battery but problem still there
There is a capacitor to coils
Have NOT check if spark plugs are resistive.
efims
Postby efims » Fri Jan 20, 2012 8:19 pm
Original plugs were resistive but decided to put in a NEW set of Resistive plugs....problem still exists
Please help
efims
Return to MS1/Extra support
Users browsing this forum: Google [Bot] and 0 guests
