I have developed a two channel knock-module as an internal add-on for MS3.
- knock module
- knock_module.JPG (66.44 KiB) Viewed 4382 times
The board mounts directly to the top of the MS3 card, fits within the standard case and works with the standard ribbon cables.
For communication with the MS3, it uses 'D14', 'D15', 'D16', 'JS11' and PM2. i.e. you CANNOT use 'LED spark' in conjunction with this board. at the same time.
- knock module installed
- knock_module_installed.JPG (77.37 KiB) Viewed 4382 times
It utilises a custom knock sensing chip from TI which features software selectable gain and frequency bandpass filters.
When the engine is running COP or sequential and the MS3 knows which cylinder is firing, the firmware allows different gains to be applied to each cylinder and the sensor level per cylinder to be reported.
The firmware allows a user-settable knock "window" (engine angle over which it listens to the sensor.)
You can take a look at these menus in the recent MS3 pre1.1 firmwares if you select "Internal" as the knock sensor.
The hardware works, but a few component values may need optimising based on field trials. The firmware is written but again needs wider field testing to fully prove it out.
I have a handful of assembled boards available.
(Edited to add more of the firmware features)
