Reverant wrote:http://e2e.ti.com/support/applications/automotive/f/26/t/118763.aspx#553334
Post #4 by a TI employee:
"The TPIC8101 only works with the resonant type knock sensor. We do not offer a device that works with the non-resonant type."
JBPerf IO/Extender?jsmcortina wrote:Electrically the card would work with MS2, but then you'd have so little I/O left it would be pointless.
Separate topic, but ... le sigh ...There's also plenty of firmware required to support the comms and windowing. I have no desire to support this on MS2.
dontz125 wrote:JBPerf IO/Extender?jsmcortina wrote:Electrically the card would work with MS2, but then you'd have so little I/O left it would be pointless.
GintsK wrote:TI page says TPIC8101 "drop-in" for HIP9011 http://e2e.ti.com/support/applications/ ... 84859.aspx
Flat response scopeshoot comes from picoscope webpage where signal is gotten by clicking engine block with wrench. It does not comes from operating engine!
I suppose they simply do not want support designs with flat-response sensors because of higher complexity.
I knew OEM ECU where HIP9011 is used together with "wide band" sensor.
And what else is strange: in their training document scopeshots are not accordant. In real life both sensors gives signal all the time and difference is visible (except amplitude) just in spectral analysis. Flat response scopeshoot comes from picoscope webpage where signal is gotten by clicking engine block with wrench. It does not comes from operating engine!
TIP's band pass filter is not so "sharp". Device still "sees" side frequencies very well. So main software should be very sophisticated to catch just knock as knock and noise as noise.
Gints
racingmini_mtl wrote:dontz125 wrote:JBPerf IO/Extender?jsmcortina wrote:Electrically the card would work with MS2, but then you'd have so little I/O left it would be pointless.
The problem is that this would take the spark outputs and you can't move those to a CAN device.
masterx81 wrote:attaching the knock sensor at the mic input of the pc (with some diodes of protection) allow to record an induced knock and lately do an fft to find the right frequency of det of a particular engine. Use the right frequency is quite important...
gross polluter wrote:Based on the FFT analysis I've done on three engines (B230F, 2JZGTE, and LS2) I've found that the formula 900/(Pi * r) gets you within 200hz of the center frequency, at least on the three engines I've tested.
nuvolarossa wrote:enter half bore in meters and you'll have the result in Hz, enter it in mm and you'll have it in kHz![]()
Please report how good it works/engine noise/etc. and datalog of it in action when tuned
BTW it's two channel, so two sensors can be connected with one module, right?
Users browsing this forum: nismoautoxr and 0 guests
