1.1 ChangeLog
1.1 ChangeLog
Postby jsmcortina » Thu Mar 31, 2011 10:33 am
HEAD/1.1
2010-11-15 KWC
Add single narrowband target table.
2010-11-10 JSM
MAPdot calc throttled to rpmcalc rate
Tiny ASM tweaks in RTC
2010-11-17 JSM
WCOP fix for 5cyl
2010-11-20 JSM
Dual+missing can sync to cam earlier (need to test this)
Config error for clash on V3 injectors or !single coil
2010-11-21 JSM
NGC4 (36-1+1) adjust by 360 deg and check cam is there
2010-12-01 JSM
Expose generic pwm duties in realtime data
Re-do boost output pins and settings
2010-12-04 KWC
Fix dashpot adder not working.
Add config error for when fan offtemp is >= fan ontemp.
2010-12-04 JSM
VSS PT2 input bug in init.
2010-12-06 JSM
Defaults on boost and idle settings
Dual+missing, keep checking for cam for first 5 seconds of run.
2010-12-08 JSM
dwell_trl wrong offset in ini
2010-12-11 JSM
EGT range checking
cam polarity check (+ comp log) fix
A few tiny ASM optimisations
2010-12-11 KWC
Update idle speed control so that the valve closes with the throttle pressed.
2010-12-20 JSM (from 1.0)
Dual fuel / semi-seq / staging
MAP sampling multi event. X/Y registers transposed.
EGO sensor options in ini
EGO 'no correction' option
EGO volt switchpoint default 0.45V
Lambda and Volts in ini
Fuel and spark tableswitching didn't mandate powercycle.
LPG temp / pressure correction railed at -100%
More code to ensure PW <= 65.535 run mode and crank mode
Clean up some wheel_fill code added but no longer required
2010-12-20 KWC
Fix rotary staged injection breakage from semi-seq fixes.
2010-12-21 JSM
Config error "whodunnit" 90%
36-2-2-2 outputs swapped if not rotary
2010-12-22 JSM
Support 16 spark outputs in arrays. 14 in hardware. MS3X + "LEDs". Barely tested.
Support 10 sequential fuel outputs. MS3X + inj1 + inj2. Visually tested only.
Support 12 sequential fuel outputs (MS3X H1 and H2)
Fix FC rotary spark again.
dwl[8] causing serial problems.
Set inj events port/pins once only in init
Fix priming
Semi-seq 2 inj per one output for 6cyl, 8cyl dual fuel or staged on MS3X
2010-12-26 JSM
First draft at antilag
Fix maths bugs in spark calcs preventing really retarded spark.
Boost second channel. Less functionality than channel 1.
2010-12-27 JSM
Fix InjI
Fix testmode crash (stack.)
Use genericIO for vss, gear input, water injection.
Make pinusage a local to save ram.
Extension to 16 injectors
-EGO
-Fuel trim
-EGTs
-outpc
-injector parameters
-small PW
Get V3 injectors working again + with staging.
Spark trim extended to 16 channels.
United sensors[] and sensors2[] in one array. Re-arranged outpc.
Per Ken's idea, split up generic_IO into four functions. Smaller code/overhead and easier to understand.
Use generic for EGT and Generic Sensors (weren't checking for clash before.)
2010-12-28 JSM
Move sections around so XGATE code aligns with 0xXX8200.
Large XGATE coding session to allocate fuel timers "just in time". Allows for V16 fuel.
2010-12-30 JSM
Keep map_ang in bounds
Fix realtime data offset in ini
V3 LEDs activating when they weren't supposed to
Water inj fixes
(Code tested ok on Cortina)
2011-01-01 JSM
Gear based boost/open-loop. Added missing code
bitmask for boost_vss
ini mods
2011-01-02 JSM
default iacstep_table order corrected
ALS re-write
Disable 4 second delay in IAC moves. (isr_rtc.s)
Temporary code for VVT cam_angle (outpc.istatus5) only for Trigger Wheel mode.
2011-01-02 KWC
Make the idle valve open at least to the last good position when valve close
is interrupted on throttle press by lifting.
Remove EAE with lag compensation option as it is no longer needed
2011-01-03 JSM
Add PK0/Tacho as spark output (for MSD)
Correct portinit defines.
Add boost bar/psi gauges.
Untested fix for "All" injector test mode.
2011-01-04 JSM
EGT actions was always on
2011-01-05 JSM
Honda Acura 24-1-1 wheel decoder
Dual_missing poll level now only triggers single edge of cam (cam interrupt not used for spark control)
vvt_angle in outpc, appears to work
Make baro-correction and mat-correction into 0.1% units
Create table of absolute tooth angles. SPKMODE4 only at present.
Extended to all modes.
2011-01-06 JSM
DDRT port init
Fixed false staging config errors.
2011-01-07 JSM
VVT config data and test options. No control function.
Miata 99-00 VVT angle capture
Re-did absolute angle-calc.
On/off VVT + inj angle adjustment
QR25DE VVT angle detection.
2011-01-07 KWC
Small VVT configuration setting name change.
2011-01-13 JSM
Add max MAT setting to ALS
-- 1.1 alpha 1--
2011-01-15 JSM
IAC pins weren't powered on when used for other functions.
-- 1.1 alpha 2--
2011-01-17 JSM
JS10 was broken as cam input - automatic polarity check used wrong TCTL register
-- 1.1 alpha 3--
2011-01-20 JSM
Added some more braces to handle_spareports for readability and used local vars for tiny gain.
2011-01-21 JSM
MS3X non-seq fuel was broken (no pin setting)
3 cyl 2 stroke seq didn't work. Likely 1 + 2 cyl might now be broken.
2 stroke rpms were doubled. Tested 3,4 cyl. 1+2 untested
>8 cyl MS3X non-seq must use Alternating
MS3X non-seq port init.
Removed redundant TC1 and TC3 interrupt code. Will re-use.
Move Rotary spark TC4->TC3 and spark outputTC2/5->TC1. TC4 now free. Either TC2/5 free.
Commonising between Rotary and 2-stroke for fuel and no. triggers setup. Needs lots of testing.
2011-01-22 JSM
Enable TC4 as second cam input.
Extend outpc for 4 cam angles.
Enable TC2, TC5 as additional cam inputs. Max 3 concurrent.
Add config error checking on cam inputs and RTC.
2011-01-23 JSM
Acura is 6cyl
Add idleVE VSS feature
No. cam teeth for VVT
Analogue VSS was broken
Rename Miata 99-00 -> 99-04
2011-01-27 JSM
Oddfire dizzy and fuel-only weren't working correctly.
Change syncfirst time limit to 'fix' 60-2 3000rpm resync
Add flex gauge
2011-01-29 JSM
Torque Convertor lockup
Merged in traction control code from 2010-04. Code a work in progress.
Add enable/disable input to TC.
TC fuel now %age
2011-01-30 KWC
Rearrange 2-rotor support: No more RX8 mode, just use COP for that.
Wasted spark + FC/FD gets same old 2-rotor single-output leading behavior.
3 rotor or 4 rotor COP with trailing now supported.
Use "rotary" for stroke to set up rotary engines (added by James).
Make all PID routines call a common PID function in preparation for 4 more
PID routines being added for VVT.
2011-02-03 JSM
Swap TC6/TC7 (rotary+normal dwell)
Add 4th cam input for VVT.
2011-02-03 KWC
Forgot to add idle P-term init code for first time through loop after
engagement. Add that back.
---- Snapshot Pre 1.1 alpha 4 ----
2011-02-05 JSM
Some VVT
2011-02-06 JSM
Add SW PWM for four VVT outputs.
2011-02-06 KWC
Add first (untested) cut at VVT PID
Slight revision to VVT PID so that vvt_run bits are not set until
IC ISR has filled in latest angle.
2011-02-06 JSM
Auto-generate variable definitions from extern defs.
2011-02-07 JSM
Allow InjI/J on H3+H4
VVT duty on sensors13,14,15,16 for debug
2011-02-07 KWC
Make VVT PID actually do something.
2011-02-09 JSM
Fix inj testmode, remove TFLG_ign and comment some debug vars.
-- 1.1 alpha 5--
2011-02-11 JSM
Renix cam support and 66-2-2-2.
VVT more vars into outpc
2011-02-15 KWC
Fix VVT PID init.
2011-02-19 KWC
<UNTESTED>
Fix cranking behavior of PID... angles are stable during crank.
Also use the hold duty if target == commanded to avoid small temporary
differences in target and commanded causing the duty to drop to 0.
Account for direction variables.
Add exhaust versions of direction, PID vars, hold duty.
Add a var for 2 cam that tells whether it's intake+exhaust or 2 intake.
Use all the intake vs exhaust vars.
Fix targets to use the var for intake+exhaust vs 2 intake cams.
</UNTESTED>
2011-02-21 KWC
Fix an ini error that allowed the 2nd table to be displayed with only 1 cam.
Also rename things to intake and exhaust so they are easier for users to
figure out.
Only calculate VVT position once we have sync.
2011-02-23 JSM
Add Nissan RB25 wheel mode (24,20,16,12,8,4 leading equidistant)
2011-02-24 JSM
Fixup flex fuel for MS3X input and simplify RTC code.
ASE doesn't restart after a momentary sync-loss
VVT cam1 uses 32bit time value.
VVT should work with crank noise-filter now.
2011-02-26 JSM
Initialise VVT angles to minimum
-- 1.1 alpha 6--
2011-03-05 JSM
7 cyl engine support (with toothed wheel)
Allow 9 cyl too (untested)
2011-03-07 JSM
VVT settings. Allow each cam to be intake or exhaust.
VVT dialogue re-arrangement
Poll-level re-checks polarity during crank/run (reports reason 18 if fails)
2011-03-08 JSM
Various VVT things for V10
2011-03-12 KWC
Add option for no VVT hold duty.
2011-03-14 KWC
Make PID disable RPMdot get ignored if using VSS.
2011-03-15 JSM
Report and do not use out of range VVT angles.
Clean up ini to remove warnings
HW PWM on nitrous 1+2 were at 4x frequency in error.
Add config data checks in boost
Add inj1 + inj2 as HWPWM options
2011-03-16 JSM
Re-arrange HWPWM frequencies (boost and idle)
Change VVT to use HWPWM outputs only.
2011-03-16 KWC
Use mariob's idea for making PID idle more responsive.
2011-03-18 JSM
VVT uses 0-255 scale on PWM output for more precision.
2011-03-23 JSM
Injector testmode PWM wasn't working.
Inj PWM calcs in own function.
2011-03-26 JSM
Staged with pri on MS3X, sec on V3 simultaneous was only firing inj1.
vvt_duty now defaults to zero until engine running.
Fix trivial but critical bug with *port_vvt undefined and clobbering MS3X fuel.
2011-03-26 KWC
Make EGO and boost more responsive using a variant of mariob's ideas.
2011-03-28 JSM
Dwell overflow was setting wrong timer.
-- 1.1 alpha 7--
Re: pre 1.1 ChangeLog
Postby jsmcortina » Sat Jun 04, 2011 5:41 pm
2011-04-01 JSM
Nissan VQ35DE decoder first draft.
Jeep 2000 first draft. Phasing unknown. Requires cam.
Jeep 2002 first draft. Phasing unknown. Requires cam.
2011-04-04 JSM
Re-arrange isr_ign to support cam decoding, mods to noise filter et al.
GM 7X cam decoder for sequential.
Add cycle_deg to other wheel patterns where it was missing.
GM7X VVT.
VVT angle calc bug (internal absolute angle calculation error)
VVT change to showing the user relative angles only. (i.e. matches up with table)
incorrect dwl_req_ang sent to wheel_fill due to railing and unsigned comparison. (Impacted dwell with very retarded timing)
Fix "time after spark"
Baro config error message
2011-04-12 JSM
Fan ctl, raise TPS% limit > 100%
Relax greying on staging outputs.
Anti-lag mods per user feedback. (Don't wait for switch to be released.)
2011-04-13 JSM
Fix simple EGO (variable size)
FSTAT |= -> =
Clear up some ini/default data warnings
-- 1.1 alpha 8--
2011-04-17 JSM
Debug code left behind in error broke "Tacho" output pin.
Default pin for tacho out is Tacho
TPS auto-zero option (checks for negative TPS at startup)
2011-04-20 JSM
Nitrous in pull-down can be disabled.
-- 1.1 alpha 9--
2011-04-25 JSM
Poll-level re-check on tooth#2
Allow ignore MAT correction during ASE
SDcard tweaks. Tested 50/50 ok with SanDisk 4G.
2011-04-26 JSM
Inj trim range doubled. Now +/-25.4% in 0.2% steps
2011-04-30 JSM
VVT on/off was 39% on.
2011-05-02 KWC
Fix for dashpot adder not getting added.
2011-05-05 KWC
More valve close/dashpot related fixes.
Back out VVT changes for x 100 resolution. Will go back when
if there is a need, and fix overflow issues while I'm at it.
2011-05-17 KWC
Back out part of 0-255 changes for PID in VVT.
2011-05-19 KWC
Fix changes from last night... changes in the positive direction were
being damped artificially due to rounding error.
Also fix exhaust hold duty.
2011-05-27 JSM
New vss/rpm gear algorithm
vss from pin input sums teeth for smoothing
2011-05-30 KWC
Redo VVT 100x resolution changes. They appear to work without overflow
with y8s' msq.
Also redo VVT "advance or retard" so that it works like all the other
PID polarity settings. Doesn't change the duty number, just changes
the polarity of the output.
2011-06-01 JSM
RC46 mod to RC51 wheel mode from MS2/Extra.
ini tweak
2011-06-03 JSM
RC46 angle tweak
-- 1.1 alpha 10--
Postby jsmcortina » Wed Jul 27, 2011 4:31 am
2011-06-04 JSM
Toyota DLI4 and DLI6. Needs testing on vehicle.
2011-06-06 JSM
Jean CAN page4/5 fix from MS2/Extra (now removed)
2011-06-08 JSM
Knock windowing
Analogue knock threshold returns
(Beware any accidental change to map sampling)
2011-06-12 JSM
Make VVT4 port setup work again.
2011-06-13 JSM
Dwell/spark queue to prevent missed events on low tooth-count wheels.
Remove dwell Countdowns.
Fix EGT setup bitmasking.
Config error 102 for semi-seq error only reported during boot.
2011-06-14 JSM
Get twin-trigger working again. Trim/re-use code in XGATE
Twin-trigger comp log fix.
2011-06-15 JSM
Revert CAN/serial change of 2011-06-06
#ifdef some test code
2011-06-16 JSM
VSS inputs and outputs can now use pulse per mile or km
VVT range check can be disabled and +/-5 deg tolerance when on
VVT logs angles in 0.1 deg
2011-06-19 KWC
Fix PID D terms (and make them more sensative for everything but boost).
Add AC/fan idleup target adders for when in closed-loop mode
2011-06-20 JSM
Validate MAP sample angles.
engine size now in cc. Used by MAF.
ini tweak
MAFmap figure allows for 2-stroke
Knock - use windowing for on/off mode too.
2011-06-22 JSM
Flex now in 0.05ms section
Flex temperature measurement (unsure if input polarity is correct)
Frequency based MAP and MAF inputs.
Tiny source cleanup.
2011-06-24 JSM
Double freq range of MAP/MAF
TIOS setup change caused a lost-sync problem > 3500rpm on 36-1
2011-06-24 KWC
Small change to main fuel calcs to lose less precision when multiplying in
VE and Reqfuel with other corrections.
2011-06-27 JSM
ini fix for Flex
2011-07-02 JSM
Fix for distributor dwell during cranking. (Seen with > 4cyl. One line missed in dwellq changes.)
-- Alpha 11 --
2011-07-02 KWC
Add option to only correct in EGO between a specific threshold.
Add CLT lower threshold, below which wastegate is held open.
Add option to turn on fan with AC button or not.
2011-07-07 JSM
Merge in Newserial branch. Beware!
Calibration tables erase and burn correctly.
Test mode working again.
Need-burn indicator working again.
First start at SDcard serial
2011-07-14 JSM
Knock - some per cyl work (debug)
ms3loader - linux version supports newserial
2011-07-17 JSM
ini tweaks per PT
V3 board injector testmode 'all'
-- Alpha 12 --
2011-07-17 JSM
MAF - do not use lookup table if in the middle of a burn.
2011-07-20 JSM
Knock/SPI work. Per cylinder gain.
ini supports powercycle required
2011-07-22 JSM
comment scidiag to prevent stack overflow
-- Alpha 13 --
Postby jsmcortina » Mon Oct 17, 2011 11:41 am
2011-07-24 JSM
Remove 'txbuf' and replace with smaller buffer.
Implement CAN_FWD with newserial
2011-07-25 JSM
Serial tweaks to allow reading/writing datax1 (read the clock)
CRC allows pflash
2011-07-26 JSM
ms3loader quick re-flash for devs (requires updated monitor)
SDcard, different VBR detection code
2011-07-27 JSM
Zetec VCT wheel mode
SD speed test working
Stream fetch works
SD file readback now working, docs need updating.
Tweak compression check size.
2011-07-28 JSM
Sector read works.
Megaview working
Allow generic sensors to share ADCs
Remove adc6/7 from outpc
Add fuel flow and consumption (need to test all staging etc. combinations.)
2011-07-31 JSM
csem fix
2011-08-01 JSM
Optispark mostly working on physical test
Knock analogue input still works if knock window output unused.
First draft of Audi type flywheel decoder.
2011-08-02 JSM
Share more code between CAS360 and flywheel
Optispark resyncs on falling edge (test code)
2011-08-03 JSM
Flywheel decoder working on stim.
2011-08-04 JSM
Flywheel changed to JS10 cam input (test code)
2JZ VVTi decoder first draft. (Untested)
2011-08-05 JSM
Flywheel 2nd phase set incorrect crank tooth.
2011-08-06 JSM
Comp logger works (somewhat) with XGATE wheel modes
Revert to 0,45,90 deg re-sync angles on opti
Option to set tertiary tach input
Allow flipping polarity on hi-res tach input.
Automatic polarity check on hi-res tach input.(now disabled)
Opti uses both edges of hi-res to see if broken MSD Opti will work.
2011-08-12 JSM
Config error for backwards TPS calibration.
Remove defective TPS calc code.
Default hardware now MS3X spark,fuel,cam
Loader tweaks
Overboost switching works as expect
2011-08-14 JSM
Serial timeout tweak.
2011-08-15 JSM
CAN passthrough working with newserial
RX8 36-2-2-2 switch front/rear rotors (were transposed.)
RTCC uses different chip
2011-08-16 JSM
CAN passthrough CRC seems to work. Read/write/burn/CRC tested using TS to remote MS2.
2011-08-17 JSM
Increase ALS timing table to allow +ve.
Serial write now copied in long,words,chars in ASM to improve speed and coherency.
Added gauges to testmode dialogue.
2011-08-20 JSM
2JZ VVTi wheel mode test/fix
2011-08-21 KWC
Fix y8s' SDcard.
2011-08-21 JSM
CAN passthrough - more tweaks - but still more work required
2011-08-25 JSM
First draft Honda TSX/D17 decoder
2011-08-31 JSM
Fix AE taper
2011-09-11 JSM
Adjust TSX angle
2011-09-12 JSM
Report SD error 30 correctly.
Opti-spark code reverted to earlier iteration. Bench tested at low speed.
Automatic noise filter added on hi-res input for opti/CAS/flywheel.
Change ini limits to 10-100 for lag factors.
-- Alpha 14 --
Postby jsmcortina » Wed Nov 02, 2011 6:36 am
2011-09-12 JSM
Remove AE debug to sensors9,10,11,12
Rail out of range barometer input
2011-09-13 JSM
PT6 was not working correctly for VVT (rotary interrupts were clobbering TIE)
Grey out "use cam" for toothed wheel
2011-09-14 JSM
Debug vars for internal knock
Split retard fine and advance step sizes
2011-09-28 JSM
2JZVVTi change cam check window teeth
2011-10-09 KWC
Add min TPS and MAP change to cause accel to trigger
2011-10-10 JSM
For > 8 cyl semi-seq don't enable non-standard injector outputs. MS3 only.
Priming pulse delay.
2011-10-11 JSM
2JZ adjust per feedback
2011-10-23 JSM
Flex %age is now real%.
Support 'A' serial for backwards compatability.
2011-10-24 JSM
Fix two small bugs that broke CAN passthrough
Re-allow backwards TPS
2011-10-26 JSM
Remove "use cam" option.
Capitalise STATUSx_ defines
2011-10-26 KWC
On-Off VVT should work on dual wheel no missing (i.e. 20v 4age)
2011-10-29 JSM
Add maf to datalog.
Add missing semaphores around various port writes (reported as fan or AC causing random rich if INJx used as output)
2011-10-30 JSM
D17/TSX allowed in VVT
Default ignition capture is Rising
VVT timed feature now working.
Add half/full sync indicator. (Changes to _all_ wheel decoders.) Needs more testing.
Fix typo in 6/7 sequential code. Likely to sync a little faster now.
2011-10-31 JSM
Allow 1cyl w/s setting
Support 2 MAP sensors (takes lowest reading)
ini tweaks
sig-PIP TFI
NGC6 cam sync in place, but phasing unknown.
NGC4 - rewrite decoder. Remove "alternate cam" option as nobody can clearly explain the sense behind it.
2011-11-01 JSM
NGC4 reverts to WCOP if COP enabled but cam signal defective.
Mazda6 2.3VVT coded, untested, but no space to enable it.
Flywheel tri-tach (audi) - corrected some bugs
Dash indicator colours.
Tri-tach, validate cam phase during cranking.
-- Alpha 15 --
Postby jsmcortina » Sun Nov 20, 2011 1:57 pm
2011-11-07 JSM
Fix incorrectly named setting value for V10/12 support.
2011-11-08 JSM
SDcard - add ability for user to alter SPI baudrate and add retry on phase19
2011-11-12 JSM
tps, map, maf now use 3pt median filter
tpsdot uses an adaptive sliding window
2011-11-13 JSM
mapdot uses similar calc to tpsdot
2011-11-18 JSM
serial timing debug
ini - remove div 0
ASE can be in seconds
2011-11-20 JSM
ASE is 0.1 second units for smoother taper
-- Alpha 16 --
Postby jsmcortina » Thu Feb 16, 2012 5:08 am
2011-11-20 KWC
Initial implementation of the initial value table for CL idle.
2011-11-21 KWC
Fix up initial value table for CL idle. This works in bench testing.
2011-11-26 KWC
PWM idle voltage compensation curve added.
2011-11-27 JSM
Water inj wasn't showing "power cycle required" in TS.
Subaru 6/7 fix from MS2/Extra.
2011-11-28 KWC
First stab at new "accel-pump" style AE.
2011-12-01 JSM
ini changes to use new(ish) TS features. (Requires TS 1.18.8+)
2011-12-04 JSM
Comment some debug code.
Apply Basic Trigger sparkcut revlim fix from MS2/Extra. (Only partial bug in MS3.)
2011-12-05 JSM
Serial errors weren't using newserial response codes for error messages. Remove them from ms3_conferr.s
2011-12-08 JSM
Add 'deadman' to MAP sampling to detect impossible events and allow engine operation.
Allow MAP window to span trigger.
2011-12-09 JSM
Boost/vac gauge
Test mode new gauges
new-AE uses %ReqFuel
Add missing (long) cast to new-AE.
Set Cortina new-AE tpsdot numbers as default. mapdot numbers are untested.
-- Alpha 17 --
2011-12-09 JSM
VSS1/VSS2 TC checks threshold.
2011-12-10 KWC
Make new AE set the engine bits properly.
2011-12-11 KWC
Add new averaging MAP sampling.
2011-12-11 JSM
Remove flagbyte0_pt5ip
Add MAP logger. Presently use dev option to enable in place of tooth logger
2011-12-12 JSM
Streamline outpc readback (~1ms -> ~500us) (Beware fallout)
For testing sensors16 = std_map, sensors15=avg_map - both raw ADC
2011-12-15 JSM
Move a setbit from flagbyte0
Replaced the temp MAP logger with the 2 byte format logger on serial page 0xf4
2011-12-17 KWC
Fix a few CL idle bugs.
2011-12-21 KWC
Fix some AC idleup bugs.
2011-12-21 JSM
Spkcut on twin trigger too (untested)
Un-do xg_conf change that broke twin-trigger spkB
2011-12-22 KWC
Add RPM-delta based idle advance ability when using CL idle
Add CLT % for new AE
Forward port gslender's "sliding window" for RPM input to PID.
2011-12-24 JSM
SDcard. whitespace changes. Check correct byte for deleted files when reporting directory.
2011-12-30 JSM
Subaru 6/7 tooth no. fix from MS2/Extra
2012-01-01 JSM
Re-write Optispark decoder. Stim tests ok.
Re-write RB25 decoder. Stim tests ok.
Re-write Nissan 16-12-8-4. Stim tests ok, but phasing unknown.
Re-do, but then comment out using hi-res for spark/dwell during cranking. Spark can hang on in stall.
2012-01-02 JSM
Nissan/opti hardware dwell/spark with safety trap.
2012-01-05 JSM
Convert RTCC serial format to BCD.
Set-clock command forwarded to Extender if enabled.
Main pseudo-time if no real RTCC enabled.
2012-01-07 JSM
Back-end work on long-term-trim table.
Add timed mode, calculate cell delta.
2012-01-10 KWC
Add dashpot that closes in at a variable speed inversely proportional to
-rpmdot
2012-01-13 JSM
Range check 'k' command to prevent illegal read.
(Also workaround gcc sign extension bug.)
2012-01-14 JSM
Config error checks on dual-fuel / staging.
Adjust RB25 offset
Adjust opti no. teeth in resync based on JSM bench testing with GM Opti.
Adjust OptiSpark offset by 1 x 90deg tooth. Add debug code.
2012-01-14 KWC
Fix MAPdot accel in new accel algorithm. The "dots" were off by a factor of 10
2012-01-15 JSM
SDcard more BCDism.
SDcard button mode hides the empty next file, then updates file creation date/time on log start.
SDcard file sequence stored in directory offset 0x0d
2012-01-16 JSM
SDcard more work on TS interaction for stop/start of logs
2012-01-17 JSM
Added printf() equivalent and implement log buffer via 'D' serial command.
More SDcard. Stop/start working ok with insertion too. Left debug code in place.
"Reset+Wait" not working correctly with insertion mode.
Get .rodata aligned ok.
2012-01-18 KWC
Add CL idle RPM window configuration to the ini file.
Change the name of "crank to run taper" to "crank to run delay"
Closed loop idle timing assistance is now named Idle RPM Timing correction
2012-01-21 JSM
SDcard. Fix delete corruption. Flag busy more often.
Re-adjust RB25 offset.
Increase default cranking rpm setting to 700.
2012-01-22 JSM
Revert RTCC internal format to binary.
Through-setting of Extender RTC time working.
2012-01-23 JSM
SD-Ready now means ready to talk to TS.
Button mode keeps logging with new files until stop commanded.
2012-01-24 JSM
Traction %slip allows TPS/MAP minimum settings
SR20 wheel mode name change. Fix deg/tooth. Adjust offset.
2012-01-25 JSM
SDcard insertion mode / manual control issue.
2012-01-27 JSM
SDcard LED fast flash during sector/dir read.
Use new SDcard/RTC menus in ini.
-- Alpha 18 --
Postby jsmcortina » Sun Mar 11, 2012 10:22 am
2012-01-30 KWC
Make dashpot apply if the valve even starts to close.
Remove the RPM window setting and filter for it, they should not
be necessary if the main RPM is filtered adequately.
2012-02-05 KWC
Make Idle voltage compensation apply at crank
Make new dashpot feature require larger numbers in the settings.
Allow the Idle RPM timing assistance to be enabled independently of CL idle
2012-02-08 JSM
Allow +/-1 tooth tolerance during SR20 sync
2012-02-14 JSM
PT4 as timer reports correct 'usage'
2012-02-15 JSM
Adjust SR20 angles by -78.0 degrees
Auto-convert #defines to .equ for ASM code.
Cam inputs check if inputs are valid in VVT mode.
Don't restrict most VVT modes to 1 cam.
2012-02-20 JSM
Un-break PT6 as VVT cam input. (Fixing TT spkB had broken it.)
2012-02-21 JSM
Knock indicator shows when over threshold.
Knock CLT scaling.
Set 50/50/50 as VVT PID defaults.
3 step. Validate input ; fix 'on' indicator.
2012-02-24 JSM
Ensure that ~100% duty injection is handled gracefully.
2012-02-25 JSM
32-2 wheel and oddfire should calculate triggers correctly
2012-02-27 KWC
Missed out a /1000 in new accel
2012-02-29 JSM
Add Viper V10 wheel decoder (untested)
Enable Mazda6 2.3 VVT decoder (untested)
Add new function to allow more wheel decoders.
2012-03-06 JSM
Fix DC1 in ini
2012-03-09 JSM
Add dedicated outpc variables and gauges for knock per cyl.
Add peak detect/decay on user visible knock variables
Knock SPI init validates returned bytes.
Viper V10 tested on bench.
Narrowband EGO gauge ini fix
2012-03-10 JSM
Knock SPI - undo validation, but check last byte is sent.
2012-03-11 JSM
Add 8 pt TPS oversample buffer. (experi)
Zero out knock_cyl data on stall
Allow VVT with Mazda6 VVT (untested)
-- Beta 19 --
Postby jsmcortina » Mon May 28, 2012 3:58 pm
2012-03-20 JSM
Allow tri-tach 4cyl with 130 and 132 teeth (untested)
Narrowband EGOV gauge 0-1V
2012-03-21 JSM
STD CAN contributed code
Add CAN broadcast interval setting
2012-03-22 JSM
Add MAP logger to ini
Fix calc_absang range error (might have impacted VVT)
2012-03-26 JSM
MAXNUMTEETH=136
Check no_teeth <= MAXNUMTEETH
2012-03-26 KWC
Change new-AE divider (/10 instead of /1000)
-- Beta 20 --
2012-04-02 JSM
Add missing close_comm_port to loader. (teg issue)
ms3loader-new_win32.exe built using mingw/g++ 3.4.5
2012-04-05 JSM
ms3loader built for MS2 works ok on Windows now
2012-04-09 JSM
Removed ALS min_tps setting per user request.
2012-04-09 KWC
(Hopefully) fix the new accel overflow issue.
2012-04-10 JSM
Oddfire fix from karlo
2012-04-11 JSM
ini file typo fixes from 93white3400z
2012-04-12 JSM
ms3loader (win32) access to > COM9
2012-04-13 JSM
ALS fuel cut was checking wrong setbit
ALS add config error if fuel cut enabled and !MS3X-seq
New-AE in 0.1%
2012-04-14 JSM
MS2 loader sensor preservation from Jean
2012-04-15 JSM
Loader reports any s19 files in directory (unix only)
Rationalise adv_offset(triggerOffset) greying and usage
more ini file typo fixes from 93white3400z (errors that TS didn't notice.)
Some tooltips in ini
2012-04-16 JSM
Fix Mario reported 4sq -> 8inj issue. (Peer review required.)
Loader changes for MS2
2012-04-17 JSM
Simplify tps_ring calc
Fix new-AE PW=0 on decel
ini mods
ALS roving idle
2012-04-20 JSM
Prevent overflow in inj trim calc with max PW
2012-04-21 JSM
Timed retard after launch
2012-04-22 JSM
Tweaks to LS1 mode.
ini mods
Drag racing features - trans-brake, throttle stop
-- Beta 21 --
2012-04-29 JSM
SDcard - when no. accessible directory entries exceeded, oldest file is replaced.
2012-05-02 JSM
Remove ability to turn off CRC checking
Align test mode data and ini tweaks for nolocalupdate. Add indicator.
2012-05-03 KWC
Rotary FC trailing coil select was backwards. Fix it.
2012-05-09 JSM
Swap phase on 420A seq.
2012-05-12 JSM
xgate.s uses new opcode and RAM offset. Requires new build tools.
Fix VSS1 driveline.
2012-05-18 JSM
Fix typo on 2ndary load.
2012-05-22 JSM
One line change in loader for Mac. Tests ok.
Support port probing for Mac loader.
Nullify unused base data to help TS CRC checks.
Only report rotary/sequential config error at boot.
Make default time/date older and more bogus.
SDcard waits a little after boot to grab time.
Clean up some debug code from sd_card.c
2012-05-22 KWC
Add delay since last on for AC idleup.
2012-05-23 JSM
LS1 mode. Make initial sync more robust and check cam position if possible during initial resync.
Chrysler 2.2/2.5. Rewrite decoder to be more strict. Remove 'cam' code.
On-the fly adv_offset change limited to +/-20deg too.
2012-05-24 JSM
LS1 mode, more tweaks.
2.2/2.5 changes.
GM7X in progress.
2012-05-25 JSM
Add code attributions.
ini tweaks from Phil Tobin.
-- Beta 22 --
Postby jsmcortina » Wed Sep 26, 2012 6:18 pm
2012-05-26 JSM
Default data - add more fields to SDcard datalog.
Default data - raise VE and AFR tables to 400kPa.
ini tweaks. Grey VE1 if MAF is primary load.
2012-05-28 JSM
Pure MAF not now influenced by MAT and synchronised calcs.
Re-arrange global/local vars slightly. (lsum/lsum2)
Allow MAF mode to use MAT correction trim curve.
Call dribble_burn more frequently to speed up burn process. (Might make interrupt driven later.)
Moved ckstall back into C.
Prime pulse delay extends fuel pump run on startup.
Dwell/discharge balancing.
Remove unused nomdwl, mindwl vars.
Shaft speed to U32 in ini
2012-05-30 JSM
ini file, expand bit sizes of algorithms to match firmware
Revised logic to determine if MAP or MAFMAP used for mapdot.
Re-arrange MAF selection logic.
Add MAF VE1 trim option
Tweaked sync logic on GM7X
Added new sensor2 sync for 2.2/2.5 Chrysler
-- Beta 23 --
2012-05-31 JSM
Fix ini to un-grey MS3X inj trim when non-sequential.
2012-06-02 KWC
Add the ability to tie Idle VE or Idle Advance activation to PID idle
activation
Make Rotary trailing back the way it was. Tester had his CAS stabbed wrong.
-- Beta 24 --
Postby jsmcortina » Wed Sep 26, 2012 6:19 pm
2012-06-05 JSM
A/C TPS/VSS hysteresis
Add GM1,2 bar to ini.
Fan control TPS/VSS hysteresis
-- Branch 1.1 --
2012-06-05 JSM
Remove some test features from code and ini.
2012-06-11 JSM
Boost2 uses shared frequency settings
Add PWM freq conflict checking
Fix PWM idle not setting frequency
Allow MAF and MAFMAP to be datalogged.
Allow MAFMAP as secondary load w/o MAF as primary
-- RC 1 --
2012-06-14 JSM
When mis-syncing at low rpms, dwell could be miscalculated causing spark hang-on.
Use dtpred_local
Shorten delayed_kill spark timer and kill on resync
Don't run prime code if config error.
Remove more dev code.
Handle 100% duty cycle on non-seq MS3X. (Free up timerpool flag.)
Reset MAPsample indicator every 1 second
TCLU port/pin default to dummies
2012-06-23 JSM
Unused config error message
ini tweak
-- RC 2 --
Postby jsmcortina » Wed Sep 26, 2012 6:20 pm
2012-07-01 JSM
Another check for MAXNUMTEETH
-- 1.1.0 --
2012-07-05 JSM
Fix alignment on xgqueue (was causing crash)
-- 1.1.1 --
2012-07-24 JSM
Remove tiny piece of unused TFI code.
2012-08-13 JSM
Fix tableswitching config error checking.
Add RTCC trim.
Tiny ini formatting fix
Remove commented debug code from serial and conferr
2012-08-20 JSM
Ensure "Fuel only" does not try to set dwell or spark flags.
-- 1.1.2 --
Return to MS3 Development
Users browsing this forum: shauer and 2 guests
