by wrenchdad » Sat Apr 21, 2012 6:48 pm
SO you built a complete new rev3.0 unit and still have the same problem? SO that makes it seem that it could be in your harness if you are doing all the testing in the car. I had a issue with the built mainboard harness, had a pin pull out of the connector, BUT I am sure that was because I do not use the hood on the connector and my harness has to turn sharply after leaving the MS box, just something to think about.
Do you have a stim? If not then I would suggest getting one so you can KNOW that your unit it good and narrow down where your problem is, in the MS unit, harness or what.
The only way I got my pots set where I could get good starting RPMs was by pulling my dizzy and MS unit out of the car and connect them all up on the bench and turn the dizzy by hand and get the pots set where I could get good RPMs down to about 80 or so. NONE of my pots, both mainboard or MS3X, are set to full CCW. I took notes as I turned them to see what worked best and I am pretty sure I have one sensor set to rising and one set to falling to get the G signal centered between the NE signal pulses. I also had to turn on noise filter to get rid of a sync lost issue at higher RPMs and after turning that on had to revisit the pots a bit to get the starting RPMs to pick up back where I had them before the filtering.
hope this helps, hang in the man, you will get there!
later wd
