(Since re-installed MAP sensor correctly)sjl008 wrote:
Now, when I put in the MS3X cpu sisterboard, the tach tops out at 65,000+ RPM! why?
This is a sign of a configuration error. In your case, it's not going to let you use a single crank wheel with no cam wheel run sequential injection. You've also set it for a 72 tooth wheel with 4 consecutive teeth missing and odd-fire, neither of which sound right.
jsmcortina wrote:Is that not a QR35DE wheel pattern? That's an existing option.
Looks like your MAP sensor is installed upside down.
billr wrote:OK, so what's new here?
Oh, I see now, this is in the "tuning" forum.
jsmcortina wrote: Is that not a QR35DE wheel pattern? That's an existing option.
...I'm really starting to get it now thanks guys.jsmcortina wrote:It looks to be the same or a very similar pattern, but that mode is presently 4 cyl ONLY. Extending it to cover V8 would not be too difficult, but would require some iterative changes to get the phasing and timing spot on.
As a first test
- disconnect coils and injectors
- select QR25DE and 4cylinders- power off, power on.
- crank engine and see if you get stable rpm with no sync loss.
sjl008 wrote:If QR25DE (Mode) is sync'd Crankshaft/Camshaft for the 1-3-4-2, then additions to a new assembly code, cab, and/or .ini file for this engine would need to be creating a 1.0.5a+...lol for TS I'm guessing? or am I overthinking here.
jsmcortina wrote:What's really needed is a service manual picture that show the crank and cam pattern with cyl#1 TDC compression indicated.
e.g. something similar to this: http://www.msextra.com/doc/triggers/36-2-2-2_%23cam.jpg
jsmcortina wrote:Your crank isn't 36-1 though. It is 36-1-1. That needs a special decoder.
You can use the "composite logger" to record your exact crank and cam patterns.
Set spark mode to "log crank and cam", power off, power on.
In diagnostics, "log to file" and then Start a "Composite log"
Crank for 10-15 seconds.
"Stop" and untick the log to file. Post that log here.
jsmcortina wrote:The existing code doesn't support 36-1-1 (like that) with a single tooth cam, so you wouldn't be any further forwards.
sjl008 wrote:jsmcortina wrote:Your crank isn't 36-1 though. It is 36-1-1. That needs a special decoder.
This is using a "NEW" cam "CAP" I described making with only 1 (TDC position @ cyl 1) slot? or just use the stock one?
Which do you want and I will post here.
