I'm recently megasquirting an ls1 engine from a camaro 99 model installed in a Nissan s13 chassis, and would like to know if i have to adjust anything in the MS3X card ? I didn't touch it yet...
Also how to add a second MAP sensor for barometric compensation ?
I'm a newbie in the ls engine family world, can anyone help me out with some wiring and technical info, like the firing order convention terminology? I mean where is piston number one and how to count the rest ???
What is the type of the crank and cam sensors? I mean are they both VR or Hall type ?
How to setup and wire the idle control valve ?
And finally how to make the Nissan tacho work...
Thanks a lot for your help
