I have been trying to figure out a minor issue with my VSS setup. My MPH reading appears to be roughly 3 times higher than it should be. For example, my log file shows approximately 220 MPH with I'm really doing 70MPH.
I have two magnets mounted on my drive shaft 180 degrees apart. I'm using a coil pickup (VR sensor). I condition the VR signal through one of Jean's VR conditioner boards and then run the signal to the table switch input.
Below is a screen shot of my VSS setup and I have attached my msq.
Just one thought, the screen tells me to enter my wheel diameter in meters and I did, but that sounds a little odd as it is the only metric input. Should this be feet instead (a difference of a little over 3....)
Any ideas would be greatly appreciated.
Thanks!
