Matt Cramer wrote:What exactly are you using for RPM input?
Fastspec2 wrote:Are you still useing a distributor?
zuki1018 wrote:Thanks for staying with me.
Its been so long i cannot remember.
Would it help narrow things down if pulled my MS box to upload a front/back picture? I do remember going back/forth with my dizzy on low to high, high to low. Not sure if having that backwards would cause these spikes or cause something more major.
Also I found a topic on keeping shielded pair away from high current wires. I realize that mine do go into my wire loom at the firewall and are 'somewhat' close before my 12v supplys (to hall, injectors, & coil) branch off to the battery and the shielded pair go through the firewall to MS.
Matt Cramer wrote:Try jumpering it for VR input, and use more solder.
