RPM spikes & duty cycle drops
Postby zuki1018 » Wed May 16, 2012 7:38 pm
Running MS1v3. 1.6ltr Geo Tracker motor with a T25 Saab donor turbo.
Hoping an expert tuner or two could take a quick look at my log file. Right out of the gate at a time of about 675 you can see rpms jump from 24xx up to 63xx as boost is starting to build. Pretty fast afterwards the PW drops to 0.
A tad up at time of 684 boost is quite a bit higher... duty/PW goes to 0. I do realize the fuel table jumps from 99 to 115.
My best guess is that I am running out of fuel. Stock injectors from all i have found on the net are rated at 175cc. Stock fuel pressure regulator.
Maybe you have seen some similar symptoms to point me in a direction or two?
Thanks a lot in advance.
zuki1018
Re: RPM spikes & duty cycle drops
Postby Matt Cramer » Thu May 17, 2012 5:36 am
What exactly are you using for RPM input?
Postby zuki1018 » Thu May 17, 2012 1:33 pm
Matt Cramer wrote:What exactly are you using for RPM input?
Thanks for the response Matt.
Input using a crank mounted 36-1 wheel with 3-wire hall. Output to the factory internal coil dizzy. Another (deleted) recent log file had a max RPM spike of like 15,000.
zuki1018
Postby zuki1018 » Thu May 17, 2012 3:39 pm
So the more log files I look at, the more it looks like an RPM spike/sync issue.
Im not sure whats causing that additional smaller tooth reading. The hall is a new one from DIY. The truck ran great pre-turbo install. I am guessing I was getting sync issues pre-turbo ...but they weren't as apparent.
EDIT: I just noticed the batt voltage at time of 697 drops to 11.3
New battery, new alternator ...sigh.
zuki1018
Postby Matt Cramer » Fri May 18, 2012 5:37 am
The slightly longer tooth shouldn't make the MS1/Extra wheel decoder lose sync. Can you post a tooth log of when the problem is happening?
Postby zuki1018 » Fri May 18, 2012 9:42 am
Sure... I did a tooth and datalog at the same time last night. I have lite version of all software so its hard to interpret tooth logs in excel to compare.
zuki1018
Postby Matt Cramer » Fri May 18, 2012 11:26 am
Hard to say for sure if anything in that log should make you lose sync. How is the RPM input circuit set up?
Postby zuki1018 » Fri May 18, 2012 12:48 pm
Thanks for staying with me.
Its been so long i cannot remember.
Would it help narrow things down if pulled my MS box to upload a front/back picture? I do remember going back/forth with my dizzy on low to high, high to low. Not sure if having that backwards would cause these spikes or cause something more major.
Also I found a topic on keeping shielded pair away from high current wires. I realize that mine do go into my wire loom at the firewall and are 'somewhat' close before my 12v supplys (to hall, injectors, & coil) branch off to the battery and the shielded pair go through the firewall to MS.
zuki1018
Postby Fastspec2 » Sat May 19, 2012 12:31 pm
Are you still useing a distributor?
Fastspec2
Postby zuki1018 » Sun May 20, 2012 6:59 am
Fastspec2 wrote:Are you still useing a distributor?
Yes, factory internal coil on the G16 engine.
zuki1018
Postby Matt Cramer » Mon May 21, 2012 5:47 am
zuki1018 wrote:Thanks for staying with me.
If you don't know, I strongly recommend opening the box and finding out.
The 12 volt supply wires are not very high current except the coil wire.
Postby zuki1018 » Mon May 21, 2012 9:37 am
The G16 has low impedance injectors if that may open up some avenues of suggestion.
Input: 36-1 crank wheel with DIYauto hall. Pretty sure i added a 1k resistor when i wired it in.
Output: looks like I chose Low to High, then 5v
R12 has resistor
Removed C30 and ran the top side to 5v on proto
Here is the front/back picture
http://www.driftwoodchimes.com/zuki1018/Pix/052112122417.jpg
http://www.driftwoodchimes.com/zuki1018/Pix/052112122352.jpg
zuki1018
Postby Matt Cramer » Mon May 21, 2012 9:49 am
Try jumpering it for VR input, and use more solder.
Postby zuki1018 » Mon May 21, 2012 9:59 am
Matt Cramer wrote:Try jumpering it for VR input, and use more solder.
So you mean to remove :
TSEL to OPTOout
TACHSELECT to XG1
And jumper:
TSEL to VROUTInv
TACHSELECT to VRIN
zuki1018
Postby zuki1018 » Mon May 21, 2012 10:42 am
Done.
So far no spikes during idle/warm-up. Will do some driving logs later this evening. Thx.
zuki1018
Postby zuki1018 » Tue May 22, 2012 6:06 am
I only had time to drive around once last night.
Around 538 my rpm spiked to 22,000. I believe this is when my transfer case popped into neutral while shifting. Theres also something a bit corkey around 615.
Overall so far ...so better. I dont see any irregular rpm spikes other than the 1 major one. I ended up blowing a U joint last night. These trucks weren't made to have twice the torque and large tires.
What does the VR circuitry do differently over the Hall?
zuki1018
Return to MS1/Extra support
