8pin HEI ground wire???
Postby Rickster » Tue May 22, 2012 9:01 pm
MS2-extra V3.0 board - Chevy 350 TBI from carb with IAC control - HEI 8pin distributor
DiyAutoTune wiring harness
I am using this:
http://www.megamanual.com/ms2/V3assemble.htm#ew
at the section "External Wiring with a V3.0 Main Board"
as my wiring diagram ( I saw no "extra" specific diagrams)
Looking at this page for reference:
http://www.msextra.com/doc/ms2extra/MS2 ... htm#wiring
at the section "Wiring the HEI module:"
I see that the ground pin is missing in the diagram. It states above it that that the "G" pin is for a ground. Is that just a standard ground to the engine block, or is that tied to the sensor ground pin #19?
The reason I ask is because of this article:
http://www.diyautotune.com/tech_article ... 2-nova.htm
at the section "How do I wire it up?"
shows the "G" pin going to the TPS return. The diagram above shows that TPS return is going to the sensor ground?
To confuse things further for me,
this page:
http://www.megamanual.com/ms2/GM_7pinHEI.htm
at the diagram"HEI 7 pin wiring diagram"
shows "G" going to pin #26 not #6 as stated in (http://www.msextra.com/doc/ms2extra/MS2 ... htm#wiring)
and also shows using a relay?
Rickster
Re: 8pin HEI ground wire???
Postby Rickster » Thu May 24, 2012 9:24 am
Anyone?
I'm going to start building my new ECU and upgraded stim this weekend. Id like to finish the harness before then.
In a nut shell, I just need to know what ground to tie the "G" pin to on the 8pin HEI (sensor ground from ECU or the ground wires going to the engine block).
Rickster
Postby Matt Cramer » Thu May 24, 2012 9:44 am
Just posted in a similar thread - I believe it's a logic ground with the power ground supplied by the module's mounting pad.
Postby Rickster » Thu May 24, 2012 9:55 am
Thank you!
Is there a protocol for requesting changes/additions to the manual?
Rickster
Postby jsmcortina » Thu May 24, 2012 12:49 pm
I'll take a look at the manual. However, do be sure to only use the MSEXTRA manuals. The "megamanual" can be quite different and incorrect for MS1/Extra, MS2/Extra or MS3.
Postby jsmcortina » Thu May 24, 2012 3:11 pm
I updated the MS2 and MS3 manual pages to include HEI8 diagrams and show the G pin.
Postby Rickster » Fri May 25, 2012 11:39 am
Thank you James
Rickster
Return to Board assembly and testing
